Old 2009.04.05, 04:55 PM   #1
NomaOnAir
Transponder power leads.
I have recently had the need to wire my car for a transponder.
It only needs a +/- power leaves ( a full size servo female lead)
I was wonding if soldering the the wires to the +/- neg. for the board would be fine ? or could it effect the performance ?
thanks ,
Eddie
Satin Black , where its at !
NomaOnAir is offline   Reply With Quote
Old 2009.04.05, 09:42 PM   #2
ianc
ianc's Avatar
If your car has a 2.4 board, test for current at the ICS plug and use that instead. My friend Dan is using this method, apparently with success.
ianc
ianc is offline   Reply With Quote
Old 2009.04.05, 10:25 PM   #3
NomaOnAir
Its a mr01 ... I actually decided to just get some longer leads and run it externally , rather then inside the chassis hidden.
Transponder wire power hook up... Hekyl Mini-Z Racer MR-02 14 2008.12.30 11:37 AM
V2 Power Board TinRacers Atomic 1 2007.06.14 12:07 PM
Making a power supply out of a PC power supply unit arch2b Mini-Z Science 18 2005.07.24 07:40 PM
Yay!! Got power back... Wedginator Off-Topic 9 2005.05.06 04:04 PM
Alternative Turbo Power Installation Mondo Setups 16 2002.04.02 07:23 PM
