Old 2009.05.14, 08:57 AM   #1
ZicZicZoom
Mini Z Driver
ZicZicZoom's Avatar
Smile Damper Questions
i am relatively new to mini z racing and my damper does not center properly it is shifted to the back. and also i am wondering which spring setup to use
Top-
Gold-Hard
Blue-Medium
Green-soft
Bottom
Gold Hard
Blue Medium
Green soft
Lastly i am wondering if low friction discs are worth it?
I started this thread because i am sure that i will have many more questions about dampers
Remember we race R/C's for fun
ZicZicZoom is offline   Reply With Quote
Old 2009.05.14, 01:51 PM   #2
MantisMMA
tire schredder
MantisMMA's Avatar
start off with green/green and 1000wt silicone oil. make sure you sand the damper plate and the disc with 2000 grit sandpaper on a flat surface.
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Old 2009.05.14, 10:32 PM   #3
ZicZicZoom
Mini Z Driver
ZicZicZoom's Avatar
thanks and do u have any advice on the damper not centered when neutral? i can post a pic if u want to better explain it
Old 2009.05.14, 10:59 PM   #4
It's likely that you've got the damper plate mounted on the wrong set of holes; normally things should line up. Got a pic of your rear end?
Old 2009.05.15, 08:54 AM   #5
ZicZicZoom
Mini Z Driver
ZicZicZoom's Avatar
Smile Pic of my Rear End
Here are the pics of my rear end
Old 2009.05.15, 08:55 AM   #6
ZicZicZoom
Mini Z Driver
ZicZicZoom's Avatar
Holes
about the holes i have it mounted in the 94mm holes and same with the motor mount so that is not the problem.
Old 2009.05.15, 09:19 AM   #7
cowboysir
You may have sourced your problem...the triangle shaped T-plate mount on the chassis is normally used for RM t-plates and not MM t-plates. You should have a piece that is just the retangular plastic piece with the t-plate holes somewhere. The trinalge damper spacer is inhibiting flex of your t-plate which at the MM size would be benificial to have.
In the grand scheme of things it's not all that bad to have the damper disks off center like you've shown but try switching t-plate spacers (if you don't have just a rectangular spacer you could trim the trinagle plastic bit off) to allow for the t-plate to sit flat....that might free up the damper position.
my custom body album...
Old 2009.05.15, 01:08 PM   #8
Cowboysir is correct. The triangle t-plate spacer is for RM, which uses longer t-plates. You want to use the rectangular MM one, or cut off the triangle on the RM one. After removing/changing that should solve your problem.
Old 2009.05.15, 01:54 PM   #9
Tjay
Tjay's Avatar
Z: Definitely cut that triangle piece off or you can get PN's new T-plate mount. If you don't want to cut that, I'll give you one of my stock MM once. Just swing by the shop.
If you are running soft H-plates, run hard spring bottom and soft spring top. This is what we use at the track and it seems to work well. Also use a little bit of dampening oil. I use 25 or 30 wt.
Oh yeah, polish the damper plate (don't go crazy with it but just polish down the uneven surface on the plate). As Marcus mentioned, polished the disc as well. You can use 1500 grit also.
Old 2009.05.15, 06:59 PM   #10
ZicZicZoom
Mini Z Driver
ZicZicZoom's Avatar
Thumbs up
Thank you so much guys this was a huge help
Tags
damper, damper springs, mini z, mr 02, pn lcg
New pn 94mm motor- Does it fit the atm ssg 94mm damper plate system erixxst Parts and Hop-ups 6 2008.08.28 03:30 PM
PN Racing MR02MM LCG Disk Damper Motor Mount LBRC Mini-Z Racer MR-02 29 2007.02.24 02:26 PM
main damper and damper plate system PINCIR Mini-Z Racer MR-02 10 2005.09.23 04:06 PM
can a pro, help me install a main damper pls?? Teek Beginner Questions 4 2002.06.20 09:42 AM
