Old 2010.11.30, 10:37 AM   #1
SaiTam
Are you Fetted?
SaiTam's Avatar
MR-03 board Fet job (Stacked) photo request
I did a 3 layer stack and only to find out later that it does not clear the chassis top cover left rear hole. How did you do yours? Thanks in advance.
Old 2010.11.30, 12:39 PM   #2
slanted stacks likely. i'm sure someone here has photos.
Old 2010.11.30, 12:48 PM   #3
yasuji
PN RacingTEAM Driver
yasuji's Avatar
wow 3 on top.... how many on the bottom?
we do 2 on the bottom and 1 on the top!
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
Old 2010.11.30, 03:39 PM   #4
SaiTam
Are you Fetted?
SaiTam's Avatar
Bottom pads are destroyed. I will go with 2 layer or single. Thanks.
Old 2010.11.30, 03:42 PM   #5
pinoyboy
pinoyboy's Avatar
Mine is straight up like yours, so I had to cut the cover a lot. With the cover on, my fets are touching the under side of my disc damper and the screw to hold the disc damper down almost touches as well
strange issue after FET job on mr-02, HELP? builthatch Miscellaneous Discussion 0 2006.04.01 10:25 PM
easy fet question on 01 board techno Mini-Z Science 5 2005.07.05 07:33 PM
need a fet board. bdreeft Miscellaneous Discussion 0 2003.06.25 06:52 PM
How do i know if one of the stacked FET is fried? Vagabond Parts and Hop-ups 3 2003.02.11 01:16 PM
