Old 2009.11.01, 09:24 AM   #1
MikeL
Painter Guy
MikeL's Avatar
Xmod radio help
I don't get it, I can run an AM miniz with xmod crystals, but I can't run an xmod with xmod crystals in a miniz radio? I have the barricade xmod for my son and the stock radio is horrid. I want to use on of the KTs I have around for it instead. Is there some trick I need to do?
I've tried 3 radios, KT, Losi micro-t, and my 3pk with AM mod, xmod and yellow band crystals.
2.4 MR02 WTF, MH Spec tube damper
2.4 MR02 Std front end, MH Spec tube damper
http://www.MikeLdesigns.com
http://www.majsrc.com
http://www.nyrcsuperraceway.com/
MikeL is offline   Reply With Quote
Old 2009.11.01, 09:33 AM   #2
Felix2010
The Xmod AM-band receivers do not work with any other AM-Band Tx's or modules except for the Xmod Tx itself. Don't know why they made it this way, but there it is. One option is to put a Mini-Z PCB in an Xmod chassis, something many people have done actually. There are tutorials on here I think, haven't looked in a long time. But I understand you frustration MikeL. I would probably run my Xmods tenfold more if they were compatible with Mini-Z Tx's.
Old 2009.11.01, 09:48 AM   #3
Scrapper
Stu
Scrapper's Avatar
Send a message via MSN to Scrapper
mike if u send it to me wit an am board i can have it done for u for free as long as u send me some small heatshrink for those wires
i have one already converted also
Swaggerific Boss Status
Scrapper is offline   Reply With Quote
Old 2009.11.01, 01:23 PM   #4
MikeL
Painter Guy
MikeL's Avatar
Thanks, I looked at the tutorial you mentioned and I can defintely handle it. Good thing 2.4g cam out or else I wouldn't sacrifice a working board for this thing
Old 2009.11.06, 10:39 PM   #5
wildthing
RC addict
A friend of mine needs help on his brandnew Xmod.
The steering would work on only one side (if set normal - right hand driver) it would turn right but not left. If you reverse the setting (left hand driver) it would not turn left but not right. Any suggestions what could be the culprit?
wildthing is offline   Reply With Quote
FS: Highly modified KT-18 radio color01 Mini-Z Marketplace 0 2008.09.11 01:45 PM
First Photos of Transformers Movie Radio Shack Xmod Prototypes arch2b Mini RC 6 2007.07.07 01:27 PM
XMOD Evo F-150 For SALE! Sky Miscellaneous Discussion 0 2006.11.15 09:14 PM
Newbie Review of Mini-Z vs XMOD vs XMOD EVO bemoore Beginner Questions 6 2005.12.14 02:48 PM
Xmod Turning TNB Mini RC 8 2004.06.10 12:32 PM
