Go Back   Mini-ZRacer.com Forums > General Discussion > Setups
Old 2002.09.06, 10:11 AM   #1
Skylineboy
ZoomZoom
Skylineboy's Avatar
Square CLK front rims seems to be a bit loose.....
Hi everyone...
Just got my Square CLK alloy rims yesterday and I fitted them onto the Z. I've tighten the wheel nuts according to the Mini-Z instruction manual..... and the front wheels seems to be a bit loose. Is it normal or do I have to tighten it more? I've got Kyosho ball bearings in the wheels.
Any information will be appreciated.
Thanks,
Skylineboy
Skylineboy is offline   Reply With Quote
Old 2002.09.06, 10:20 AM   #2
butler
Mini-Z Chief
butler's Avatar
Send a message via MSN to butler
Are they wobbly loose? Or loose as in you can move them side to side along the axle?
Haynes Manual: Prise away plastic locating pegs...
Reality: Snap off...
Haynes Manual: Lightly...
butler is offline   Reply With Quote
Old 2002.09.06, 10:23 AM   #3
Skylineboy
ZoomZoom
Skylineboy's Avatar
Yes butler, your description is spot on!
Old 2002.09.06, 10:38 AM   #4
Skylineboy
ZoomZoom
Skylineboy's Avatar
They are wobbly loose and you can move them side to side along the axle too.....
Skylineboy
Old 2002.09.06, 10:50 AM   #5
butler
Mini-Z Chief
butler's Avatar
What happens if you put the bearings on the axle on their own are they loose?
Do you the bearings fit well in the wheel hubs?
Did you have this problem with your plastic rims?
Did you have these bearings in the plastic rims?
Old 2002.09.06, 08:11 PM   #6
mini-z
Administrator
mini-z's Avatar
Do they wobble if you use the stock bushings? And are you using real Kyosho bearings, or Duratrax?
Old 2002.09.07, 08:49 AM   #7
Skylineboy
ZoomZoom
Skylineboy's Avatar
Hello butler,
The bearings actually fit onto the axle quite well. It doesn't seems to be loose.
The bearings are actually quite loose in the wheel hubs.
I didn't have this problem with the plastic CLK rims.
I did have the bearings in the plastic rims before I took them off and put them on to the alloy rims.
Hello mini-z,
I haven't tried putting on the stock bushings since I've gave them to my cousin's Z as spares. However... the bearings are true Kyosho bearings.
Thankyou so much to both of you trying to locate the problem for me.
After answering butler's questions, please correct me if I'm wrong........I think the problem comes from the hubs.... they are a little bit too big and the bearings always drop out when I remove the wheel.
Skylineboy
track width comparison... herman Mini-Z Racer MR-02 22 2003.09.24 06:05 AM
That loose front end.. Digisane Mini-Z Science 1 2003.08.23 01:07 PM
Product Review: the CLK Front Bumper Plate West.F1 Parts and Hop-ups 6 2003.02.27 10:49 PM
Square Front Knuckles NitroNSX Parts and Hop-ups 8 2003.01.14 04:57 PM
my rookie review: front end springs West.F1 Mini-Z F1 MF-010, MF-015 12 2002.06.30 11:08 PM
