Old 2009.06.06, 08:44 AM   #1
littleleon
Send a message via Skype™ to littleleon
Getting the correct gear mesh
I have just installed a front one-way and rear ball diff into my MA010 after running with the kit gear diffs since buying the car second hand.
The gear mesh for both the front and back is just terrible. I've done a lot of on-road racing with 1/10th scale and I know what a bad mesh sounds like and this is definitely it. It's like a coffee grinder (ok, slight exaggeration)
However, I'm at a loss as to how I could possibly get the diff gears to mesh better. I've read elsewhere that you can use shims, but I'm not sure where they should go to make a difference. Can anyone help me out? How can I get my MA010 to run silky smooth?
littleleon is offline   Reply With Quote
Old 2009.06.06, 10:04 AM   #2
-J-
-J-'s Avatar
Send a message via AIM to -J- Send a message via MSN to -J- Send a message via Yahoo to -J-
Shims should've been provided with the diff and the one way assembly. Were they?
If they were, you put the shims inbetween the diff and where the bearing goes on the diff to adjust spur to pinon gear mesh. With shims, you can get it about perfect.
-J- is offline   Reply With Quote
Old 2009.06.06, 07:36 PM   #3
littleleon
The One-Way didn't come with a shim. The ball diff did.. I'll give that a go. Thanks.
Old 2009.06.06, 09:25 PM   #4
-J-
-J-'s Avatar
You shouldn't have to use all the shims that came with the diff on the diff. You can use the leftovers in the front, but be careful not to cause binding by over shimming it.
Old 2009.06.07, 04:15 AM   #5
Skv012a
Skv012a's Avatar
I've actually tried this to kill 95% of that horizontal diff "wobble" and move the spur gear away from the pinions for a lighter mesh on my ball diffs. It sounds and feels the same to me, but hopefully in a long run this could prove its worth.
New site.
Old 2010.03.09, 10:11 AM   #6
alexandrubarbat
there is somebody who have an ma010 which run silky smooth (silently)?
alexandrubarbat is offline   Reply With Quote
Old 2010.03.10, 12:03 PM   #7
greenepa76
greenepa76's Avatar
I've shimmed up my diffs and applied some dry graphite lube used in pinewood derby cars. Made a difference in noise. Not 2WD drive quiet, but at least 25% reduction.
greenepa76 is offline   Reply With Quote
Stock AWD Gear Diffs - Dry or with 15k grease? Felix2010 Mini-Z AWD MA-010, MA-015 12 2009.08.10 12:05 AM
The perfect gear mesh (MR)? Skv012a Mini-Z Science 13 2009.05.06 06:57 PM
26T--->28T ball diff gear= longer gear ratio correct? pinoyboy Mini-Z AWD MA-010, MA-015 8 2007.11.05 01:45 PM
GPM .. they have many parts.. are they all available? bcuzau Mini-Z AWD MA-010, MA-015 5 2006.03.14 09:12 AM
Help again, trying to mesh pinion gear w/ diff gear!!! walds11 Beginner Questions 2 2003.06.11 05:06 PM
