Old 2014.01.24, 07:17 AM   #1
Mike Keely
ASF PC board programming
I have the setting module and the setting card that links the ASF PC board to the radio. What I was wondering was how you navigate through the process and will it work on a Helios? The module came with the Euros so I would figure I would be able to change the settings using it. The setting card shows the older box style module but how do you change settings in the car using the radio? I will take a picture of the modules and try to add it to this thread.
DG-Designs / Brooklyn Hobbies
Old 2014.01.24, 08:08 AM   #2
Mike Keely
Here is the picture. It goes in were you would plug in the normal Mini-Z module in the radio.
Old 2014.01.24, 10:15 PM   #3
KWT
From what I read, you change the settings thru the front LCD on the radio. I don't think it will work on a Helios. It uses DDS.
Old 2014.01.25, 08:34 AM   #4
Mike Keely
You are correct. I spoke to KO and they said that it would only work with the Eurus. I will be playing with it today just to see if I notice any difference.
shop.tinyrc.com: Holiday Savings Start Today & End In 2014! Mrs Mini-Z Mini-ZRacer.com Announcements 0 2013.11.27 09:34 AM
shop.tinyrc.com: Holiday Savings Start Today & End In 2014! Mrs Mini-Z Newsletters 0 2013.11.27 09:33 AM
Pin outs Diagram of 02's ASF Board? machgo5go Mini-Z Racer MR-02 1 2011.01.04 08:48 PM
WTB: KT-18, ASF Board, or Box stock ASF Chassis JeremyC Mini-Z Marketplace 0 2009.11.01 06:06 PM
Weird ASF board... cowboysir 2.4GHz ASF System (Auto Selected Frequency) 12 2008.12.20 04:50 AM
