Old 2018.12.28, 04:52 PM   #1
Thorvald
Thorvald's Avatar
Two new parts out for MA-03F - Brace and Front Alum Cover
Found these today:
http://rc.kyosho.com/en/mdw301.html
http://rc.kyosho.com/en/mdw302.html
Old 2019.01.03, 01:55 PM   #2
HaCo
02-Racer
HaCo's Avatar
Thanks for sharing!
Old 2019.01.04, 06:56 AM   #3
Are these necessary or simply flashy bits?
Old 2019.01.04, 07:50 PM   #4
ghost chili
I think these are more flashy bits than necessary. I really have to push hard to introduce flex between the battery section and the front bulkhead. I'd like to see an optional tie rod set with different toe settings. I never liked how the FWD came with toe out on the front. Seems to make the car more twitchy and harder to keep on a straight line, at least for me.
ghost chili is offline   Reply With Quote
Old 2019.01.05, 09:15 PM   #5
Kremzeek
Have you tried these?
http://rc.kyosho.com/en/mdw003.html
Edit: nevermind.. only the rear works with the FWD
Kremzeek is offline   Reply With Quote
Old 2019.01.06, 07:03 PM   #6
ghost chili
Yeah, the AWD tie rods are shaped differently and won't fit the FWD. I figure it's just a matter of time before a set is released.
Old 2019.01.26, 09:27 PM   #7
Kremzeek
I found these on Shapeways. I have no idea if they are different widths. I messaged the creator and asked but no response yet.
https://www.shapeways.com/product/UU...li=marketplace
Old 2019.02.07, 05:17 PM   #8
Kremzeek
Someone on FB bought a set and they are different widths. Unfortunately, they're made out of that grainy 3D printed plastic so they don't work very well.
Old 2019.02.08, 09:47 AM   #9
cowboysir
Any 3d printed part used in RC application will need some finishing to smooth part interface areas. A bit of effort and I'm sure these parts will perform to your liking.
my custom body album...
Old 2019.06.05, 10:17 PM   #10
ghost chili
I bought a set of these to try myself. While they are well printed and are a direct drop-in fit, the plastic is softer than stock and results in a more flexible tie rod. I tried all three settings and found the car to handle worse. I think the flexible plastic is causing the steering to become erratic to the point I couldn't keep a straight line even with a gyro unit at max gain. A good attempt, but maybe if the plastic was more rigid.
