Old 2019.04.17, 01:55 PM   #1
RCPMini-z
rcptracks.com
Mini-Z USA Cup Series 2019
Rules and regulations are complete. Can't wait for the racing to begin.
RCPMini-z is offline   Reply With Quote
Old 2019.04.17, 09:30 PM   #2
mugler
Thumbs up
Very Interesting.
Would be curious to find out dates locations and competition structure when they're released.
Old 2019.04.18, 11:41 AM   #3
RCPMini-z
rcptracks.com
Yes, plans are for some Kyosho sponsored events before the end of the year.
Old 2019.04.18, 08:21 PM   #4
Can we submit questions on the rules that can be passed along to Kyosho? I'm not sure we have anyone from Kyosho USA reading along anymore...
Why such a limited list of permitted Autoscales? This seems like a counter-intuitive move for Kyosho given the extensive catalog of Autoscales to pull from. Especially given the motivation to generate sales with retailers. By the time events happen, it is likely you will not be able to find one or more in stock anymore given the limited production runs made.
Old 2019.04.19, 05:57 AM   #5
Seems to be quite a bit short on specifics, don't you think? While we are on specifics, are you required to use the hokey little adapter that converts the Futaba 3PK series radios to 2.4 gigs or is it allowable to just convert the module for direct use.
Curious as well as to why there are no "LM" classes?
Old 2019.04.19, 06:07 AM   #6
I assume that the limited body options reflect more recent production runs, bodies that have stock in the system. I do not like the limited body options. Could this be in the scope of not providing unfair advantage for newer racers with as rich ASC collections? Or just to promote sale of the newer ASC bodies which they have available for sale?
There are plenty of points that I could make issue with the rule set, however, this is the Kyosho Cup so I will not go there. My only true issue is the limitation of bodies. And it looks like the MM2 mount is limited only to brushless motors (probably to restrict it from the brushed only RWD production class).
It is hard to judge about the radio, whether it will be required to use the r246 adapter with the 3pk.
Old 2019.04.19, 06:27 AM   #7
Since I look for the same things that you do in a rule set it just becomes glaringly obvious that they are trying to restrict some options.
Old 2019.04.19, 06:44 AM   #8
Well, lets be honest, the Kyosho Mini-Z Cup rules have ALWAYS been stringent. Iíll say the same thing to those that complain about PN rules, Itís a manufacturer series they are sponsoring, they get to make the rules. We may not like or agree with them but they are putting the time, money and effort into the series and should be thankful for that. Iím thankful for any organized racing series we can get frankly and as always will adapt to the rules as necessary.
I believe your on the right course in that the list of permitted auto scales are current production models but as i mentioned, that availability is shaky at best and has a high likelihood of causing more problems than it solves. The old R8 for example is getting a re-release... one of the preferred racing bodies and not on the list...?
If iím Not mistaken, the Jpn series has more classes that include LM? Itís been a long while since i tried following the Jpn rules graphic and asked for translations.
Lets hope there is some flexibility with the implementation of the rules. Itís one thing to put them on paper and another to implement them across the entire NA market when dates/times are still unknown as currently tied to available stock items. I can appreciate that notion, to pick from currently available items to create a more neutral playing field but NA availability is not the same as Jpn and inventory levels are finicky at best.
It may read like a lot of boo-hooíing but Iím all in. I fully support PN in their endeavors and will likewise support Kyosho. Lets not forget, we havenít had the Mini-Z Cup since 2004 or there about, itís nice to see it come back.
Old 2019.04.19, 07:23 AM   #9
Im not trying to bash their rules, I am in the same boat as you... I understand it as a manufacturer cup will be quite restrictive, but I have a very difficult time trying to shoehorn any of my equipment into a class that is being run.
I believe that either R8 would be permissible, as it does not say the year or designate new/old like the NSX. I am surprised that the new Corvette is not on the list though, might be amended later.
Old 2019.04.19, 08:26 AM   #10
I only bring up the radio portion of the rules since I am a "lefty" that has had issues in the past with the little adapter not being as stable a platform as I might like.
Like EMU it becomes a "shoehorn" concern that makes it perhaps necessary to have to add additional equipment to the inventory just to take part in an otherwise undisclosed program. If there were solid dates and places posted for events it would be a bit different but right now all we have are some ambiguous promises of things that "may" come.
Is this whole thing just another vague attempt at creating something new and or exciting? Thanks but I'll wait for season 2 to see how it turns out.
Old 2019.04.19, 11:58 AM   #11
There were always leeway with judges discretion in years past. I would hope that would not change.
Not judging anyone here . We all know as soon as you post any kind of rules itís going to create some measure of grumbling, something PN is very familiar with as well
As mike points out, until dates and locations are announced, it still feels speculative given the previous attempts to get the cup series back in NA. Iím still excited at the glimmer of hope though!
Like emu, this series may not be a good fit for some as itís not as flexible at PN meaning your focusing on only a subset of the scale. Itís nit going to be for everyone. For retail locations, itís a glimmer of hope that it can push to get more into these locations. Hopefully itís not limited to retail locations and some active and well supported clubs get a shot. Just more speculation though until more definitive information is put forward.
Old 2019.04.19, 06:18 PM   #12
I am definitely interested in attending, as I had passed up on the last kyosho cup when I first came into the hobby.
I don't know how far I would travel for it, but I would go out of my way to get there. It would mean some new gear to comply to the rules, but that is normal for any event really.
Old 2019.04.20, 04:32 PM   #13
mugler
The way I'm reading post #3 it sounds like Kyosho America is willing to sponsor some single event mini-z races in U.S. locations where a) they carry Kyosho products and b) already have or can set up an RCP track. It doesn't seem words "Cup" & "Series" are meant literally...it would be cool if they do though... we shall see.
Old 2019.04.20, 04:54 PM   #14
It certainly sounds like a series of single events, which is fine by me. Not like we have any other series with larger tie-in's anymore in NA. The days of regional and finals past a long time ago. The Cup used to be a regional/final format and who knows, if it does well, maybe it could be again.
Old 2019.04.20, 06:04 PM   #15
It sounds like a series of regional events, possibly followed by a finals event if the is enough of a following...
FS: 14 Mini NASCAR Cup Car 2 kits Mini-Me-Zee Mini-Z Marketplace 8 2013.03.03 11:36 AM
2012 R1WURKS.com So-Cal Mini-Z CCS(championship cup series) yasuji RCKenon, Baldwin Park CA 18 2012.03.01 12:34 AM
MC3/ Reflex Racing Points Series info Sinister_Y MC3, Toronto, ON, Canada 0 2011.01.26 09:03 PM
Where can i get treaded tires for my mini z in the USA Incubusions Parts and Hop-ups 6 2002.09.05 06:43 PM
