1. My track is coating my car in a fine white dust, and it is making the tires very slippery (PN rcp slick 6d all around). I have used windex but it only helps for a few minutes. Is there other tires I should try? maybe ones with a tread?
2. I have a 98mm body. Does the stock center shaft fit or do I need an extended shaft?
3. After about 80 laps I broke the rear center shaft mount . Do I need to replace the whole chassis?! I have done a lot of work on my Overlands, and the AWD looks a bit easier to deal with. Does it takes hours to change the chassis? 20 minutes? I am getting the PN alum. shaft mount, is there any other thing I should consider? This seems to be the most annoying breakage possible for an AWD. The screw just cracked off the chassis and took the threaded plastic part with it.
4. Where can I find spurs and center shaft pinions? I can't find the 98mm extended ones that fit!!
This is the most fun Ive had in rc for a while..mini-z's are sweet, but a modded AWD on rcp is just rc perfection. I am so bummed I broke that mount, now I'm out for a few days
The happiest adults are the ones doing what they did as children.- Pablo Picasso
Is there some kind of rcp maintenance I should know about? Vaccuuming, brushing, any thing like that to keep it in good shape?
Vaccuming is good for sure. Just make sure you leave the brushes on the hardwood floor setting, or whatever makes the brushes the furthest from the floor. Some others might have some other tips on this. This is how I maintain our clubs track.
In need of a FET upgrade? PM me!
Concerned about sending off your precious Mini-Z? Don't be!
Do you think the 20 and 30 Kyosho tires are softer than PN 6 degrees? Are all #'s in tires on the same softness scale, such as 20 PNs would be the same softness as 20 kyosho's? Thanks.
I ordered those pinions, but I am going to stick with my opriginal shaft til it has a problem.
Does the whole servo casing/gears/pot thing have to come out? Are the wires very fragile like the Overlands? I had to resolder them because they fell right off the servo motor AND the pot while I was changing the chassis..I hope to not have the same problem.
If you're replacing the entire chassis, yea of course you'd need to swap everything over. You'd need to slide out the servo casing/gears/pot. To avoid putting the servo gears together again, just be careful and slide out the unit as one and pop it entirely into the new chassis.
The wires can be fragile as with any board, not just the awd. Just take it slow and keep checking if everything is clear and free as you slowly pop it out. I've removed my awd board a few times and haven't had to resolder.
As far as what actually broke on your chassis, is it just the little plastic cross bar that is screwed down and sits on top of the center shaft? http://www.atomicmods.com/Products/K...et__12231.aspx
Very top right little piece is the cross bar.
Rereading your first post, are you saying the screw hole is stripped also? If so, you would and probably should change the whole chassis. You could just get ... http://www.atomicmods.com/Products/K...et__12229.aspx
But I'd really recommend the blue/grey chassis again and I don't think they sell just that main chassis.
Or you could glue on a crossbar, but that could be all bad and would be a pain to clean/replace the center shaft in the future.
kyosho tires are soft in general and none of the numbers are even close to being the same!! PN 20 fts are really good for the AWD and teh 6 rears are good too.
MantisWorx www.rcshox.com
professional RC products
It is definitely the chassis, where the bearing sits, and where the mount bar screws in. I have ordered the chassis and the PN mount, and new pinions all around, they looked pretty used. From the exploded views the balance act of holding al the gears/pot/ thing together looks a lot easier then the Overland. I should get all parts in tonight so I'll post what I get done tomorrow.
I feel like I have too much grip in the front with the same #'s all around, so I'll grab some new wheels next order and try the 20/30 kyosho combo.
1. Try some softer tires, skip worrying about tread. The title says your car is setup like Christian Tabush, as is mine. For RCP I use atomic 20 degree rear and 30 degree front (semiwides all around). Christian Tabush 98mm setup does not use wide rear wheels. I find this tire setup to work very well for me and my girlfriends car.
2. The stock shaft works if you get 98mm gears. Basically the gear itself is longer.
3 IF the mount itself broke and its a part of the main chassis, you'll have to replace the chassis itself. This took me around 2 hours my first try. Now it takes me around 30 minutes PROVIDING I don't have to change the servo gear casing (which you shouldn't have to). Strange you had that issue with the blue/grey chassis. This only happened to my girlfriends original smoke chassis. From my experience its not a common problem (I've been racing for two years with the same car and its never happened to me.
