Old 2019.02.03, 01:19 PM   #1
Hudy Tire Truer Belts
Looking for long term solution to replacing these o-rings. Hudy lists them as rubber 25mm x 2.5mm but unsure what type of rubber and there are MANY types. The cheap rings we currently buy at the hardware store do not seem to be soft enough shore thus too much tension and generate to much heat and keep snapping. O-rings are cheap if you know what to look for so hoping someone out there knows what type of o-ring is best for this application.
Old 2019.02.03, 05:18 PM   #2
mugler
mugler's Avatar
Blue box on page below should take care of a lifetime supply of o-rings for Hudy truer
https://www.harborfreight.com/catalo...nk%2Cf&q=Oring
Old 2019.02.05, 06:41 AM   #3
Traveler
of both Time and Space
Traveler's Avatar
That's what I did! Much cheaper!
FS: HUDY Tire Truer 103100 unwritten Mini-Z Marketplace 0 2015.02.05 03:02 PM
FS: Like New HUDY Tire Truer 103200 unwritten Mini-Z Marketplace 0 2015.01.15 01:13 PM
WTB Hudy tire truer Mike Keely Mini-Z Marketplace 0 2010.01.06 08:32 PM
December 3hr Endurance! Programmers Stafford Mini Z Racers England 26 2009.08.22 06:20 PM
FOr Sale-- Hudy Micro Tire Truer gasman1 Miscellaneous Discussion 0 2007.01.03 08:49 AM
