Old 2010.07.14, 12:19 PM   #16
byebye
byebye's Avatar
If you use the PN A-arm setup, you dont need the lower carbon plate for kingpins... You should be able to mount it to the servo case (Mr02 chassis), and it shouldnt interfere with the board...
Okay I looked at the a-arm setup and yes with the MR-02 servo case I hacked up I could do it! I think that would be an awesome setup.
If you hack up the MR015 chassis with the dremel, you should be able to mount the battery terminals to the chassis...
I still have bits and pieces of the MR-015 chassis. I think this would be a down the road project. I'm enjoying just being able to drive it.
I was thinking that the PN 90mm MM motormount may be useful, especially with the DDS system that is included. You only need to fabricate a bridge over the board for the DDS post...
Yeah that is a great Idea! I was wondering what the best route would be. I may be able to fab up somthing using dds posts and the outer holes on the board. Just a thought.
Kris
Sas Pro Set Up. Cherub1m Mini-Z AWD MA-010, MA-015 310 2011.05.24 10:08 PM
wtb SAS PRO OR SASPRO V-ll eztuner12 Mini-Z Marketplace 3 2008.12.17 07:33 PM
Anyone else tried newest IW Pro Boards? Taazz iWaver 25 2006.01.10 12:15 AM
