Go Back   Mini-ZRacer.com Forums > General Discussion > Beginner Questions
Old 2017.02.15, 02:57 PM   #1
ang4all
miniz buggy sports not engaging reverse + some other questions
Hi guys, I'm very new to miniz, I just got a miniz buggy MB-010S (http://www.kyoshoamerica.com/MINI-Z-...d_p_24594.html) I got the readyset model that includes the KT19 transmitter.
1. It seems that has a problem engaging reverse. Sometimes reverse works; sometimes does not not, I will try to explain. With the buggy going forward, I'm breaking and the buggy stops, then I'm pushing the trigger again and the buggy is not reversing (as many times as I try to push the trigger, it will never start reversing). Now if a go forward again, brake, and then push the trigger, reverse might work.
I've noticed that if after brake, a buzz noise comes from the buggy, then the reverse works fine. If after brake, there is no sound coming from the buggy, then reverse is not working.
Can you please help me ?
2. Also I have another newbie question on my K19 transmitter, there is a knob labeled 'Light', what is the use of this knob ?
3. Is there a way to set Throttle trim on this ?
4. I've found a technical manual pdf on kyosho website (http://www.kyosho.com/jpn/support/in...B010TG-T12.pdf). Are these settings (brake power adjustment, throttle range adjustment, ics...) apply to the sports version as well?
Thanks!
Angelos
ang4all is offline   Reply With Quote
Old 2017.02.15, 03:14 PM   #2
Throttle trim adjustment might help the reverse issue. I have never used a KT-19, but the knob to the left of the steering wheel should be throttle trim. Dial it a little forward, or a little back and see if it helps the reverse engage.
I read that the knob labeled light allows adjustment of an optional light kit.
There are no ICS adjustments for the Sports version. It is a stripped down version to reduce cost.
Old 2017.02.15, 03:25 PM   #3
ang4all
Thanks emu, unfortunately i cannot find the throttle trim knob, the one to the left of the steering wheel is the light knob which i tried it and doesn't do anything with the throttle
Old 2017.02.15, 05:14 PM   #4
My lack of experience with the KT-19 here, I thought it had throttle trim adjustment... you could try a reset of the transmitter? http://mini-zracer.com/forums/showth...ht=kt-19+reset
Old 2017.02.15, 11:25 PM   #5
ang4all
I willl try that, thanks.
Old 2017.02.16, 01:32 PM   #6
there is a reset you can do on the TX, it should fix this issue. search for KT-19 reset and it should come up.
2 MR-03 Sports questions ilove599xx Beginner Questions 27 2015.04.10 11:56 PM
Brushless Miniz Buggy....already! targetingxmod Mini-Z Buggy MB-010 6 2012.02.06 06:44 PM
miniz wheelbase and more silly questions michvin Beginner Questions 5 2004.04.14 11:50 AM
New to MiniZ! Some questions.... BovineD Beginner Questions 18 2003.04.28 07:43 PM
