Old 2018.09.21, 07:12 PM   #1
xray
Easy Lap transponder question
Anyone ever removed the guts out of the plastic case? I have a clearance issue using the Ferrari 599xx and need just a tiny amount more room and removing the plastic part will give me that.
xray is offline   Reply With Quote
Old 2018.09.23, 09:31 AM   #2
TPDazzle
I have, but it was accidental. The cases pop apart pretty easily. I had one come apart during a 8 min HFAY race and it eventually got wrapped around my front suspension. The only damage was losing 1.5 minutes of laps. It worked fine once I repositioned it. I have glued all my Easylap cases together since then, but I considered removing it. If you are worried about it getting damaged you could probably put some heat shrink around it with a hole cut for the sensor. The ILap transponders are heatshrinked. I would try it, the worst thing that would happen is you'd have to buy another one, which is not ideal but is only $20.
Old 2018.09.23, 01:05 PM   #3
Mike Keely
I run the same body and had the same issue.. I cut the case off and I did not have any problems with it.
DG-Designs / Brooklyn Hobbies
Old 2018.09.23, 01:10 PM   #4
xray
I tried prying it open, but was glued together along one edge so I ended up cutting it open too.
Old 2018.09.23, 04:16 PM   #5
Most people I know using these have de-cased them and heat shrink wrapped them.
Old 2018.09.23, 04:22 PM   #6
xray
Thats my goal as well, probably doesn't need it but shrink wrap is cheap!
M.H.S. Racing Discussion HobbyShopOwner Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 9983 2016.07.02 01:25 AM
*NEW 2013* Updated I-Lap Transponder for Mini-Z coming soon! Felix2010 New Products 4 2013.01.16 01:19 PM
Lap Timing Using the Microsizer Timer bemoore How Fast Are You? Online Points Series 2 2007.09.14 12:57 PM
easy fet question on 01 board techno Mini-Z Science 5 2005.07.05 07:33 PM
really easy transmitter question reaperman93010 Beginner Questions 2 2004.01.11 09:40 PM
