Old 2012.12.14, 02:54 AM   #1
diy - lm dummy chassis
had a nissan r390 for the longest time (from route 246)... but didn't have a dummy lm chassis so i could display it...
so what can you do? er... modify a mr02 dummy chassis of course...
tools needed:
dremmel with drill bit & cutting disc bit
since this is a 102mm body... and the mr02 dummy chassis extends out only to 98mm... you have to relocate the rear axle 4mm back... this is easily done with the help of mr. dremmel with the drill bit...
however putting it on the chassis... wtf?
looks like the length is ok but the wheel to fender clearance is... not
measuring the front wheel to fender clearance, it looked like it was 3mm...
measuring the rear wheel to fender clearance, it looked like 6mm...
so i figured, if you lower the notch of the dummy chassis, by 3mm, the fit would be perfect...
Old 2012.12.14, 03:09 AM   #2
calling mr. dremmel...
this is mr cutting wheel / disc
measure 3mm from the upper notch and lower notch and... cut out the notch...
then do the same thing for the other side...
before...
after...
Old 2012.12.14, 03:26 AM   #3
now for the wheel to fender & car pics...
Old 2012.12.23, 02:53 AM   #4
optimaforever
Autoscale fan
optimaforever's Avatar
That's a very nice DIY idea, herman!
Optimaforever - My Gallery on mini-zracer.com - WTB List
https://lh5.googleusercontent.com/-7bL6U0Vu-Bg/UZ3drBL7clI/AAAAAAAAt5M/r9VhCnSppF4/s500/Autoscale%2520Studio%2520banner3_resize.png
Autoscale Body List
search for autoscalestudio
optimaforever is offline   Reply With Quote
Old 2013.01.07, 12:45 AM   #5
thanks for your comment...
there are not much dummy chassis for LM bodies over here...
glad you liked it...
Old 2013.03.22, 06:27 PM   #6
optimaforever
Autoscale fan
herman,
I'm trying to find the right wheels-tires combi for this one but what offset did you use?
It seems it has been designed with LM wheels in mind, and therefore racer rear wheel seems too small compared to the wheel arch...
In the real car the rear wheel arch is smaller I think... and they use BBS type wheels
Autoscale Body List
Old 2013.03.23, 07:29 AM   #7
Originally Posted by optimaforever View Post
herman,
good question. i will have to check, the rims i used were rays rims made by route 246, i forgot the offsets... i'm guessing that the best fit would probably be inch up rims (made by square)… they are 21mm (1mm wider than the std. size 20mm diameter rim) and they have them in the bbs design... i actually got a set on my ferrari 360 and they are really beautiful… i havent tried them on the r390 though… problem is though they are pretty rare these days... anybody know where to get a set? i believe there's a post on them on the forums (search square)… hope this helps
Old 2013.03.23, 07:36 AM   #8
found the thread
click here to see square rims
WTB: LM Dummy Chassis ocean rodeo Mini-Z Marketplace 0 2010.03.03 01:54 PM
FS: a variety of Mini-Z chassis' cowboysir Mini-Z Marketplace 22 2008.06.02 07:40 PM
dummy chassis kryten Stafford Mini Z Racers England 0 2008.05.29 11:40 AM
Overland Dummy Chassis DAMZer Mini-Z Overland MV-01 10 2003.03.20 02:49 PM
Wanted Auto Scale Chassis and display cases MaukaRunner Custom Bodies 0 2002.09.17 05:19 PM
