Old 2002.02.11, 01:59 AM   #1
Sharpshooter
Mini-Z Pro
Send a message via ICQ to Sharpshooter
Longer antenna problem
I took a 10 inch antenna from a crappy Lamborghini r/c car and adjusted the antenna to fit my mini-z.......but before i did that, i turned on my controller but didn't extend the antenna for that and put it on the table...i walked away from the controller with my mini-z (with orginal antenna on) to see the range for that...after i installed that 10 inch antenna, i did the same but the distance was only about 1 feet... is that normal? or should i be using another wire?
Sharpshooter is offline   Reply With Quote
Old 2002.02.11, 04:35 AM   #2
kikkoman
Guest
Posts: n/a
What was the range for the standard antenna?
I have made a double-length antenna from piano wire and it works fine. I will try this measuring-method on it and compare to the standard one...
Food for thought... longer antenna? color01 2.4GHz ASF System (Auto Selected Frequency) 5 2008.04.05 10:41 AM
IW02 controller problem (antenna wire on the loose) Rokkiheebeli iWaver 4 2006.02.07 12:24 PM
Antenna Install Problem stepchild Beginner Questions 13 2005.11.22 09:52 AM
About the dreaded shorted antenna problem SweRacer Beginner Questions 10 2003.04.23 01:53 PM
Internal Antenna Ideas Teek Mini-Z Science 6 2002.07.11 10:57 AM
