Old 2008.01.06, 04:48 PM   #16
Ancient Artist
Ancient Artist's Avatar
..thanks for the response John. Great point on where the value is on these batteries.
Regardless of the additional power they may provide, a matched pack will always give you greater consistency and run time then loose cells.
That goes a long when setting up your gearing,motors,etc in any class.
SING ME UP WHEN THE FIRST BATCH IS READY FOR PRODUCTION !!
Ancient Artist is offline   Reply With Quote
Old 2008.01.06, 05:59 PM   #17
CristianTabush
CristianTabush's Avatar
John, these are definitely going to be a must for high level stock racing for sure. I know that you are just getting done with these, but what would be awesome is also a slightly lower voltage, longer runtime matched battery for modified racing. Higher voltage in these little suckers in mod is definitely a hindrance to performance. Great to see you are getting involved in this. Your brand will definitely bring more recognition to racing this scale.
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2008.01.06, 06:33 PM   #18
john,
i sent you a pm on joining our 'ask' forums
Old 2008.01.07, 06:08 PM   #19
JC@TSR
JC@TSR's Avatar
arch2b I just PM'd you.
I will have more info up in the next few days. If you have any questions just let me know. I will do my best to answer every question ASAP.
Thanks
John at Team Scream Racing
www.teamscreamracing.com
978-337-0429
1/12 Stock Cleveland US Indoor Champion 2007
18 Time 1/18 Off Road National Champion
18 Time 1/18 On Road National Champion
26 Time East Coast Champion
RCX 2WD Stock Mini-Z Champion
2008 RCX F1 Stock Mini-Z TQ/Champion
2008 RCX Pan Car Mod Mini-Z TQ/Champion
2008 19T UK National Champion
2005 Stock UK National Champion
2006 4 Time BRCA UK Champion
JC@TSR is offline   Reply With Quote
Old 2008.01.07, 09:22 PM   #20
pinoyboy
pinoyboy's Avatar
I was thinking of buying more orion 900HVs, but I'll wait and buy some of these instead . Subscribed
Old 2008.01.07, 09:38 PM   #21
wcrotty
Send a message via AIM to wcrotty
Hi John,
Smyka is a great guy. I have raced with him for years.
I'm also wondering if they are repackaged Team Orion Cells or are they something new? I know when i was doing testing of intellect cells performance was dependent on the freshness of the cells (PN gets the direct and airs them to the states). When i was testing my Team Orion cells on my turbo GFX i was getting ~19.5 (195) for AIR 1.145 Avg voltage at a 6 amp discharge and a .9 cutoff.
This was without zapping the cells.
I can't wait to get a pack to do some testing.
PN Team Driver
2008 PN World Champion
2008 PN Canadian Champion
2006 PN World Champion
2004 Kyosho Cup National Champion
2003 Kyosho Cup National Champion
wcrotty is offline   Reply With Quote
Old 2008.01.08, 08:34 AM   #22
i sent you an email from the pm message
Old 2008.01.08, 08:42 PM   #23
JC@TSR
JC@TSR's Avatar
Pulling some late nights to get the info up here for these cells. I also wanted to say these are not repackaged Orion cells. I have been testing AAA cells from a large amount of companies for some time now and found these to be the best. I have Orion cells coming to test against my cells in the next day or two. I will post all the data between the two cells when I get it. Hopefully my cells will come out on top. We will just have to wait and see.
It never fails, you try do something to better a sport and a huge company jumps in a spoils all your fun. That's the way it goes in this business though.
Thanks
978-337-0429
Old 2008.01.08, 09:24 PM   #24
lfisminiz
lfisminiz's Avatar
Dont worry, if you have a good product...we will buy. And i know you will.
Old 2008.01.10, 09:18 PM   #25
JC@TSR
JC@TSR's Avatar
I got the Orion cells today and here is the info on them right out of the package. Charge rate on both cells is 1.0 amp and Discharge rate is 6.0 Amps.
431 SEC 1.134 VOLTS IR 18
440 SEC 1.131 VOLTS IR 18
434 SEC 1.124 VOLTS IR 19
415 SEC 1.125 VOLTS IR 19
427 SEC 1.133 VOLTS IR 18
390 SEC 1.141 VOLTS IR 19
420 SEC 1.132 VOLTS IR 18
425 SEC 1.126 VOLTS IR 19
430 SEC 1.130 VOLTS IR 18
440 SEC 1.132 VOLTS IR 18
415 SEC 1.121 VOLTS IR 20
428 SEC 1.131 VOLTS IR 18
My cells right out of the case
435 SEC 1.132 VOLTS IR 18
438 SEC 1.132 VOLTS IR 18
440 SEC 1.134 VOLTS IR 18
428 SEC 1.140 VOLTS IR 17
432 SEC 1.131 VOLTS IR 18
439 SEC 1.129 VOLTS IR 18
426 SEC 1.136 VOLTS IR 18
435 SEC 1.140 VOLTS IR 17
430 SEC 1.128 VOLTS IR 19
440 SEC 1.129 VOLTS IR 18
422 SEC 1.137 VOLTS IR 18
428 SEC 1.139 VOLTS IR 17
This is the first cycle and will post the 2nd tomorrow. I am setting up a new computer this weekend so I can post some charts to view. I will also test the zapped cells when the computer is up and running. The Orion cells and my cells look pretty close number wise. I did not fudge the numbers just to make it look like that either. LOL!
I will also try a 3.0 amp rate to see how they react over a longer discharge pattern.
I can tell just by what I see in these cells that a matched pack will be the key to longer runtimes and performance through out the race.
Thanks
978-337-0429
Old 2008.01.15, 07:08 PM   #26
JC@TSR
JC@TSR's Avatar
I am sorry for the delay, but I am having some trouble with the software install. I am working on it and should have it up and running this week. Sorry again. It looks like there will be a Ask Team Scream Racing Forum up soon as well.
Thanks
978-337-0429
Old 2008.01.21, 06:36 PM   #27
JC@TSR
JC@TSR's Avatar
Sorry for the delay everyone. Finally got the software up and running, cells are on right now and I will post the results from them tomorrow. I have been cycling these cells with a 6 amp discharge and a 3 amp discharge. The 6 amp data was posted and 1.12 to 1.14 with IR 17-19. The 3 amp rate gives more data as if you were in a race. The motors peak out at about 1-2 amps under the right condition. I am thinking of sticking with the 3 amp rate because of this. The cell discharges for a longer period of time as it would in a race and shows how it can handle the long discharge curve. I am doing this for the racers so let me know what you think. I do not mind changing something before they go on sale. That will be very soon now that I have the software up and running. I just want to stick to a solid system for matching these cells.
Thanks
978-337-0429
Old 2008.01.21, 07:42 PM   #28
CristianTabush
Actually John, I've data logged this and the motors peak at 5-6 amps coming out of corners. The average discharge for a mini-Z race is going to be in between 2-2.5 amps during a race. 2.5-3 amp discharge should be good.
Cristian Tabush
REFLEX RACING USA
Old 2008.01.21, 09:40 PM   #29
Gigibesi
when is the estimated time of arrival?
Gigibesi is offline   Reply With Quote
Old 2008.01.24, 10:52 PM   #30
pinoyboy
pinoyboy's Avatar
Are these still going to be for sale by Feb. 1st like Davey G mentioned in the first post? It would be a great b-day present for myself
Team Scream Racing Matched 900 Mah Min Z Cells JC@TSR Team Scream Racing 36 2012.06.12 06:52 AM
Mini-Z Shopping Mall Race Z_408 Events 39 2008.09.28 04:01 PM
Maha MH-C9000 WizardOne Charger-Analyzer for 4 AA / AAA rkk Batteries, Chargers and Dischargers 51 2007.08.02 03:49 PM
