Old 2018.05.04, 11:42 PM   #1
jude26
MR-03 Rear Suspension Plate
My MR-03 has a bit of a rear wheel gap. Would like to lower the back end a bit. Would changing out the rear plate to a 4.5 make it softer and in turn lower the back end?
1/28 Scale RC
MR-02 FET
MR-02 ASF
MR-03 VE
MA-010
jude26 is offline   Reply With Quote
Old 2018.05.05, 06:36 AM   #2
What are you using for a motor pod? If it is an aftermarket unit you may find it easier to just flip the rear axle pills to lower the rear ride height by raising the rear axle in the pod. By doing this you will not compromise the handling that you already have.
Old 2018.05.05, 06:51 AM   #3
Pictures always help diagnose the issue... it could be an axle height adjustment if using an aftermarket pod, a shim between the t-plate and motormount, or relocating the side clips of the body slightly higher to lower the body on the chassis. Hard to know what is needed if we don't know what you have on the car.
A narrower t-plate is not the appropriate way to adjust ride height. It is reducing lateral spring for the rear end, effectively your anti roll characteristic more than vertical spring. Going very light on the t-plate will give more off throttle steering, as the front outside wheel will take more load through the corner. On throttle the car will have less steering. I personally prefer a wide frp t-plate with top shock to control ride height/longitudinal spring.
Old 2018.05.08, 07:55 PM   #4
jude26
Here are a couple of pics
1/28 Scale RC
MR-02 FET
MR-02 ASF
MR-03 VE
MA-010
Old 2018.05.09, 07:54 AM   #5
If the motor pod has axel spacers that are adjustable, swap to spacer that reduces the gap. If your motor pod doesn't accommodate this feature, you can find ones that do. Depends on how much you want to spend to correct an aesthetic issue. Well, if you also competitively racing, it can be a performance issue as well.
Reset the body clips to adjust the gap.
This is a common issue for some autoscales. Looks fine on the dummy chassis but rides high on the actual chassis.
Old 2018.05.09, 08:57 AM   #6
I often like a little rake to the body... helps aero on higher speed tracks. Also helps if you plan to use LM rear tires or oversize wheels.
With the stock motor pod, it looks like the only option without replacing the pod is to adjust the side clips. If you have a hot glue gun, it makes it easy to try different positions without damaging the body.
Remove three body clips and raise them 1-2mm, stick them on with double sided tape to see if the gap is where you like it. Then mark the height and glue on. If you space them inwards a little, the body will have a little less tendency to pop off in a collision.
Old 2018.05.15, 12:33 PM   #7
akura2
PROFESSOR TRUTH JIMMY ICE
akura2's Avatar
Send a message via Skype™ to akura2
I shad the same issue with the Audi body on my MA020VE
I just did the clipendectomy and that helped a lot
Before and after:
"He who KNOWS he's stupid is actually kinda smart"
akura2 is offline   Reply With Quote
PN Racing MA-010 AWD Front Double -A- Arm Suspension. eztuner12 Mini-Z AWD MA-010, MA-015 345 2011.10.07 10:05 PM
About tweak and how to perfect balance your 4wd suspension. eztuner12 Mini-Z AWD MA-010, MA-015 7 2011.04.15 04:56 PM
94 mm rear suspension advice Volt Setups 7 2008.12.29 03:31 PM
Mounting of Kyosho's Carbon Rear Suspension Plate Bandie Mini-Z F1 MF-010, MF-015 0 2004.12.23 04:46 PM
Product Review: the CLK Front Bumper Plate West.F1 Parts and Hop-ups 6 2003.02.27 11:49 PM
