2011.01.07, 12:39 PM
#61
Javier
Originally Posted by Chicken Little
Skinny/90mm: Store approved non modified PN 70 turn motor required, 90mm only with front 0 offset wheel all around (square set-up)
Thanks! So the "square set-up" on the Skinny means all wheels need to be 0N front and back for a 0N,0N setup, correct? A 0N,0W would not be allowed?
2011.01.07, 01:55 PM
#62
El Pollo Loco
That's correct. You must use fronts all around (square set-up).
2011.01.07, 02:16 PM
#63
Javier
Got it. So it is a narrow front setup (MR-015 width equivalent) chassis set to 90mm with 4 narrow, 0 offset wheels.
And any body that would fit on that setup would do? So if I mount rear narrow 0 offset rims to a 90mm Porsche that normally uses 0N front and 0W back would that be legal?
Thanks!
-j
2011.01.07, 10:50 PM
#64
El Pollo Loco
Technically it would, but the most common types they use are the Silvia, Mini Cooper, VW Beetle or any of the MA010 drifter bodies with the narrow tire set-up. It just would not look right using a Porsche body, I have tried it but didn't like the way it looked.
2011.01.08, 01:45 AM
#65
Javier
Thanks! Will you be there tomorrow?
2011.01.09, 11:29 PM
#66
Are you Fetted?
1/8/11 videos are now on Youtube. Click on my signature to see them. 10 races uploaded.
2011.01.10, 12:25 AM
#67
Slip Angle Chaser
Nice Videos Sai. Great racing, lots of very close battles.
Philip Vincent
2011.01.10, 12:12 PM
#68
Philip, that Mini was working... I thought for sure once you got in front you would pull away from the field. I dont know if I increased pace, or you dropped off... but I started to close the gap a little. Your mini was very good in the left side of the track, my car seemed to be better on the right side. You can see that difference in the video...
In the Hatch class, I knew I couldnt make one mistake. Elvin's Megane is fast, my Subaru was smooth and carried lots of corner speed but lacked the acceleration that his Megane had.
I had a great run with Ron in LM. I hit the board on lap 2, and he got by. I raced him very close for a few laps trying to force an error...
2011.01.11, 03:18 PM
#69
Slip Angle Chaser
Hey Eugene, yeah the Mini was working very well, it was easy to drive and I think your right I started to lost punch and top end at the end of the race. It could have been batteries or maybe I need to learn to save my batteries a little more during the race. But without a doubt a great race.
Philip Vincent
2011.01.11, 04:19 PM
#70
The amount of pressure you gave me early... I knew I couldnt hold you back for long. Especially because I couldnt get the power down with the RX-7 as well as I could with the Mini. Maybe I need to try a different t-plate, with a little more f/r compliance. I broke the t-plate that I had the first time I raced with the Mini, and am looking for a few options... I dont want to go too soft laterally, as I already lift the inside front wheel from time to time if I push it too hard. I am using an ATM silver 5.5. Maybe I should try an ATM blue 7.5 and see if that helps. I may also try a Kyosho wide. PN t-plates are more front/rear stiff than laterally stiff, and dont work very well for my setup style, especially since my Mini is a DDS car not a Tri-damper setup like most of my other cars. I have a few ideas to try for the next race.
2011.01.11, 11:29 PM
#71
Slip Angle Chaser
Yeah I agree the PN t-plates are very f/r stiff I prefer a bit more f/r compliance, at least enough to where the car (race ready) settles down about 1 to 1/2 a mm once the car is placed on the ground, but still have enough suspension travel. I like some mild lateral compliance. I have most of the Atomic 03 silver plates and I believe I have all the blue 03 T-plate and they work great (blue ones are a bit softer then the silver plates). For my Mini I use an 02 with modified front end to become narrow and use the soft silver ATM 02 T-plate sometime my Mini will pick up the inside front wheel or if going in very hot into a sharp turn the inside rear wheel will pick up (I have a tendency to start throwing the cars around, I find I can reduce/illiminate 3 wheeling if I am smoother on the wheel). I made some changes to my ride height and damper plates and built another Mini with the ATM rear mount, I cant wait to try it out again. I should be racing again this Sat. at Ron's hope to see you there.
Philip Vincent
2011.01.12, 11:52 AM
#72
I plan to build another 90mm setup (with ATM mount) to compare to the PN setup as well. I think that both have their strengths and weaknesses, so they will be interesting to see which works better. I am happy that there are more than one 90mm MM mount now.
2011.01.12, 07:31 PM
#73
El Pollo Loco
Philip hey, it's Richmond. Watching the 90mm race with you wheeling your mini cooper was awesome. Hope to see more of that action between you, Jason and Eugene.
2011.01.13, 03:51 PM
#74
Slip Angle Chaser
Hey Richmond
Yeah that was fun. Hope I can drive the Mini Cooper like that again this Saturday, and this time win the race the reality the competition is tight (but pleasant and fun) and many guys there could have won the race. I was fortunate to take the win from Jason on the B main to bump up to the A main, his Mini Cooper had A main written all over it, he was on rails. I made some changes to my Cooper's damper system, will see if that translate to more corner speed.
Philip Vincent
2011.01.13, 08:01 PM
#75
Slip Angle Chaser
Philip Vincent
