Old 2009.04.01, 07:08 AM   #1
Pierro
Hacking the Dnano charger
Hello!
I'm considering the fact of "hacking" my dnano charger (and perhaps also the blade mCX one) as it uses too much fresh batteries to work.
So, here's the question, what kind of transformer can I use?
(don't know if it's the correct word in english, but I mean here a power supply like the one used to charge a cellphone, or use a portable CD player without battery)
From what I know, I understand that a transformer provide only the current required by the device that is connected. So a transfo of 500mAh for example, provide up to 500mAh, but can also provide a device that requires 350mAh.
A simple tranfo of 6V with 150mAh output could it be enough to charge the battery of the Dnano and Blade wich are respectively 130mAh and 110mAh for 3.7V?
Or should I look for one that is 130 or 110 mAh?
Or, do I even need to find a more powerful transformer to obtain the same intensity as that obtained by the 4 batteries?
(In order to avoid the double red/green LED signal that means that the batteries in the charger are low)
At first my goal is to continue to use the system LED indication of each of the two chargers, but only by using a transformer instead of 4 batteries...
Thanks a lot for your help.
Pierro is offline   Reply With Quote
Old 2009.04.01, 02:14 PM   #2
shimey
putting ew back in newb
Here is the first of many hacks that come up on google for the MCX charger. Same thing for the Losi Micro series charger. May be some good stuff you can use...
My Gallery "those now old and wise, once were young and otherwise."
shimey is offline   Reply With Quote
Old 2009.04.01, 03:10 PM   #3
Pierro
Hello!
Thanks for this link. In fact, I do not have a professionnal charger. Only a MAHA C-9000 for the mini-z.
And so, I'm looking into a way to continue using the original charger.
Old 2009.04.01, 06:54 PM   #4
Jace1283
CCMMMK
Jace1283's Avatar
it uses 8 batteries right? so thats 1.5v X 8 = 12V. so just find a 12 volt A/C to D/C adapter and solder it to the battery connectors. Yeah the current draw is determined by the battery charger so mah doesn't matter as long as its not to low. I don't think that little battery takes much current, i'm sure a 500mah(.5 A) dc adapter is safe.
My 1/28s: MR-03, MR-02, MA-010, F1, Overlands, Monsters, Xmod Servo Crawler, Xmod cars very modded
My VIDEOS: http://www.youtube.com/user/Jace1283xmod
Jace1283 is offline   Reply With Quote
Old 2009.04.02, 02:05 AM   #5
Pierro
Hello!
Both chargers (mCX and Dnano) use 4 AA cells. So, 6V.
In my mind I would put a DC plug on the chargers soldered to the cell pot and so, beeing able to use the charger with both battery and adapter. And if it's possible, the same adapter on both chargers.
So, the cheapest way of all!
Does anyone have done this before? Ideally for one of those charger, but another model is also a help. I'm not a pro in electric device and so, I prefer to go with caution before mod my chargers.
Old 2009.04.10, 01:42 AM   #6
Pierro
Hello!
I know have the answer. A 300mAh is not enough for both charger.
I went to a 1000mAh (1400 at 6v) and this works perfectly.
I will put some pics soon.
Old 2009.04.21, 08:22 AM   #7
Pierro
And here are the pics of the modification of the Dnano charger:
Works really nicely and don't destroy the Dnano charger.
Old 2009.04.21, 11:50 AM   #8
what are you using as a power source?
i like this discussion as i to do not have a hobby class charger. i simply want to use a plug in power source vs. batteries.
i have my powered pit box with 3v, 5v and 12v power outs made from an old pc psu.
Old 2009.04.21, 02:42 PM   #9
kalou60
Thanks a lot Pierrot le Fou.
kalou60 is offline   Reply With Quote
Old 2009.04.22, 04:34 AM   #10
Pierro
Hello Arch!
I use a simple regulated universal voltage adapter.
This one can get output voltage from 1.5 to 12V. with 1000mA at 12V (1400 at 6V).
It also contain different plugs.
You should be able to find something similar in any electronic shop.
The whole modification (for the two chargers including wire, plug and adapter) cost me around 15€ and about one hour with my dremel and a pretty pranky solderer.
And the big advantage of this hack is the fact that I still can use cells if I need to. So, adapter at home and club and cells if I have to move somewhere else where I can't use my adapter.
@ kalou: I got trapped!
Old 2009.04.22, 12:24 PM   #11
do you have a part number for the regulated universal voltage adapter? i can then try to find something similar.
would this work?
6V/1800mA AC-to-DC Power Adapter
Model: 273-1763 | Catalog #: 273-1763
Power your portable devices with this convenient AC-to-DC adapter. Works with devices requiring 6V and a current of up to 1800mA. Perfect for many digital cameras, mini USB hubs and CD-ROMs.
Power Device Fits Univeral Adaptaplug devices like digital cameras, mini USB hubs and CD-ROMs.
Voltage Required AC 110/120 V (60 Hz)
Power Type Mini AC to DC power adapter
Intended Device Type Products requiring 6VDC/1800mA
single voltage Yes
Power Voltage DC 6 V (1800 mA)
Old 2009.04.22, 12:32 PM   #12
Skv012a
Skv012a's Avatar
Say guys, what voltage of lipo does nano need? Can we homebrew out own, higher cap battery? Can we mod the stock charger to charge custom ones safely?
New site.
Old 2009.04.23, 02:42 AM   #13
Pierro
Hello Arch.
I would say that the one you founded will be perfect. In fact, I do believe something around 600-700mAh will be enough. It just need to give as much power as brand new AA cells.
I started with a 300mAh but it wasn't powerfull enough as the led light on the charger was dual red/green. So I decided to go 1000 and not beeing annoyed anymore. The charger will only use the power it needs so the adapter doesn't force to give less than it's maximum capacity.
The one I use is a HQ power PSU10R. Some obscur "made in china" brand... At least for me.
I get this as one day I had to replace an adapter for my computer's speakers and get one of this brand. It runs perfect since 3 years now and so I hope to get the same with my new one.
@Skv012a:
I know some guys get their own lipo for the Dnano but if I remember correctly, it is a higher capacity that is used. The voltage is 3.7 as any 1 cell lipo. If you can get the lipo to fit in the charger, I believe it should not be a problem to get it charged. But for my Dnano, I prefer keep on the kyosho stock lipo at the moment.
Old 2009.04.23, 07:58 AM   #14
Skv012a
Skv012a's Avatar
3.7, you don't say... This technically means I can just pull 1 outta my motorola and viola- fairly light, 800 or so mAh with its own control board. Sounds prospective, doesn't it? I've always wanted to utilize those in RCs, but voltage was too low for something like Zs. Now the idea seems perfect.
Plus they're 5-10$ to buy and usually come with USB chargers for them, so screw kyosho's $50+.
New site.
Old 2009.04.29, 08:33 PM   #15
well, 4aa = 6 volts. mah is pointless to worry about unless you stay above a min. which you seem to have figured out as aa mah ratings are usually 1000-2500 mah.
i just want to make sure i'm not going to fry a brand new charger and or battery. at $21, the batteries are not cheap. i thought ahead and bought an extra and plan to for each car i buy.
i really don't even plan on using the charger wit batteries. i seriously do not want to have to buy batteries to charge batteries and don't want the hassle of charging charger batteries.
i'd also love to be able to use my 12v power jacks in my travel psu box so that would require some sort of step down from 12v, ?mah to 6v, 1800mah.
WTS: 2.4GHZ Kyosho Ferrari 360 Modena MR02 with free Dnano marc Mini-Z Marketplace 8 2008.10.09 09:50 AM
[FS] Kyosho dNano ENZO pchan0 Mini-Z Marketplace 2 2008.08.22 03:53 PM
Backlight your ICE Charger PaulBoth Off-Topic 5 2005.11.25 07:31 AM
What Charger? butler Beginner Questions 4 2002.10.25 09:27 AM
Battery charger suggestion ZAppy Miscellaneous Discussion 18 2002.01.28 02:43 PM
