Old 2019.03.13, 08:49 PM   #1
Smokey_truck
Guest
Posts: n/a
Changing pinion gears on RM motor case
Looking for instructions to change pinion gear on the RM motor pod, I put PN 70t motor and stock had 6 tooth pinion and when I put 9 tooth pinion motor case won’t close, in all other motor mounts I find the piñon specific attachments but did not find in RM motors. Anyone has instructions or know how to do it.
Smokey
Old 2019.03.13, 08:58 PM   #2
SLMZ / HFAY
if this is the stock plastic mount there are some plastic spacers that you need to place in front of the motor. then you have to remove the square plastic spacer on the clip that holds the motor in. I believe with the 9 tooth you have no back spacer and the 1.5 spacer in front of the motor.
Old 2019.03.13, 09:27 PM   #3
1.5 spacer on axle side, no spacer in clip.
Old 2019.03.13, 10:27 PM   #4
Smokey_truck
Guest
Posts: n/a
Thank you
Smokey
Old 2019.03.13, 10:26 PM   #5
Smokey_truck
Guest
Posts: n/a
Thanks I will check it out
Smokey
Tags
pinion gears
I broke my Pinion gear :( philophob Beginner Questions 5 2008.03.12 08:58 PM
Help with pinion gears DigitalMafia Mini-Z Racer MR-02 5 2005.06.24 12:48 PM
pinion gears Cobra427 Motor Tech 2 2005.03.08 04:54 PM
Metal pinion gears? mini-z racing Mini-Z Racer MR-02 1 2005.03.05 02:14 AM
Pinion gears kvik369 iWaver 2 2005.01.27 06:27 AM
