New pn 94mm motor- Does it fit the atm ssg 94mm damper plate system
Hi guys
i try to fit my Atomic Mini-Z MR-02 MM 94mm SSG Damper Plate System on my new pn low cg 94mm motor mount and it does nt seem to work . The damper post at the 94mm position is not well center in the plate hole it even touch the plate on the front side
Is anyone of you had the same issue and is there a way to fix this other to set the wheelbase at the 98mm posititon
is this the same with the pn damper set ??
And while im here ! what about using damper and shock! ive seen this on some pictures
thank for your help
1st at my solo basement cup 2008
I should Stop investing on speed more in control -
First thank to all ! im a newby on mini-z scene and i trully appreciate that you guys share some time to answer my questions
as you ask Christian i post some pictures of the scene
youll see the post arm touching the plate when i set the motor arm straight
on what i think being the 94mm position
when i move the t-plate one space backward the arm fit perfectly in hole of the plate but the wheels touch the body in the wheel pit
so i figured they were a miss match between the 2 compagny
is it fixable or money waste !!!
eric
