2011.03.08, 09:36 PM
Ain'tSoldEm
Carolina Cup 2011 - Race 1 April 9 - INFO THREAD
GRAPHIC BY DG DESIGNS
Join us for the first Carolina Cup Race of the 2011 Season. We will be racing at the new Hobbytown USA Mooresville, NC Indoor RC Track. This will be our largest track event of the Carolina Cup Challenge, featuring the nearly unlimited, superfast CanAm Class! We will also be running the competitive LeMans Prototype Mod Class and of course the Stock Handout Motored GT2s. We will also have a Sportsman GT/LM class for new racers, young and old, who want to join the fun.
Track open for practice all day Friday April 8th (10:00AM - 8:00PM)
Saturday April 9th Schedule: Morning Practice (8:00AM - 11:30AM)
Qualifications Start at 12:00 Noon
Three 4 Minute Heats with 8 Minute Mains
Race Location:
HobbyTown USA: Mooresville, NC
168 Norman Station Blvd
Mooresville, NC 28117
US
(704) 799-9332
THANKS to our Prize Sponsors!
DG Designs
Team Scream
Vasquez Painting
Reflex Racing
PN Racing
Action B (FET Upgrades)
Microsoft
Atomic
Race Fees:
First Class: $20.00
Second Class $10.00
Third Class: $5.00
Use of Handout Stock Motor Included
Sportsman: $10.00 (Handout Motor not required)
Friday Practice: $10.00 per Racer, All Day
ILap Transponder Rental: $5 with harness (Available for purchase as well)
RACING CLASSES
GT2 - LMP1 - CanAm1 - Sportsman GT/LM
SEE RULES BELOW:
Grand Touring Classes
Chassis: Any 1/28th scale 2WD chassis.
Track Width: 80mm max
Wheel Base: 86-102mm
Body: Kyosho ASC, White Body or equivalent (TRP, Iwaver, X-Mod, etc...) hard plastic bodies allowed, excluding LM-LeMans Prototype bodies (See LMP class list) or Can-Am/Pan-type bodies. No thin shell Lexan/polycarbonate bodies allowed. Bodies may be altered for wheelbase but a maximum wheel opening of 31mm measured horizontally must be maintained. Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. Cabin window must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia or bumper maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 70mm max
Wing: All wings original to the body are legal. Aftermarket or non original wings must fit within the confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Electronics: Unlimited.
Batteries: 4 x AAA NiCad, NiMh or Alkaline (Lithium based batteries NOT allowed)
Wheels: Any Mini-Z type wheels, plastic or aluminum.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber Mini-Z type tires (no foam).
GT1
Min Weight: None.
Motor: Any 130 size brushed motor. Brushless not allowed.
GT2
Min Weight: 175g with transponder.
Motor: Spec motor designated by the Event.
Le Mans Prototype Classes
Wheel Base: 102mm only
Body: Kyosho LM-LeMans Prototype ASC or White Body only:
Porsche 962, any version.
Mazda 787, any version.
Sauber C9, any version.
Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. A maximum wheel opening of 32mm measured horizontally must be maintained. Cabin windows must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 60mm max
Wing: All wings original to the body are legal. Aftermarket or non-original wings must fit within confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Batteries: 4 x AAA NiMh or Alkaline (Lithium based batteries NOT allowed).
LMP1
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber tires (no foam).
Min Weight: None.
LMP2
Front: 9 x 18.5mm max
Rear: 11 x 20mm max
Tires: Kyosho LM specific tires only.
Can Am Classes
Track Width: 85mm max
Wheel Base: 90-106mm
Body: Atomic VDS (any version), PN Pan Car (any type), Le Mans Prototype or Can-Am style polycarbonate (Lexan) body (open or closed ****pit), Kyosho Le Mans ASC, White Body or similar.
Width: 85mm max.
Length: 200mm max
Height: 60mm max
Wing: No limitation other than must fall within Body Width-Length-Height envelope.
CanAm1
Min Weight: None.
Front: 11 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber or foam tires.
Batteries: 7.4V max. (Lithium based allowed).
Motor: Any 130 size motor. Brushless allowed.
CanAm2
Min Weight: 170g with transponder.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Sportsman GT/LM
Chassis: Any 1/28th scale or similar 2WD or 4WD chassis.
Body: Kyosho ASC, White Body or equivalent (TRP, Iwaver, X-Mod, etc...) hard plastic bodies allowed, including LM-LeMans Prototype bodies
Motor: Stock Kyosho or Stock PN 70T.
Driver List:
GT2
Traveler (Marwan)
Pedrocamp (Pedro)
Daddy Rabbit (Andy)
Chad508
Kromie (Eric)
EMU (Eugene)
Cosmicsoul (Jay)
Don
VAzRacer (Matt)
kwsmith (Wade)
Rodney
Connor
Rob
Pick (James)
Hrdrvr (Landon)
LMP1
Traveler (Marwan)
Pedrocamp (Pedro)
Daddy Rabbit (Andy)
Chad508
Colin
EMU (Eugene)
Cosmicsoul (Jay)
Hrdrvr (Landon)
Don
kwsmith (Wade)
Rodney
Connor
Pick (James)
CanAm1
Traveler (Marwan)
Pedrocamp (Pedro)
Daddy Rabbit (Andy)
Chad508
Kromie (Eric)
Colin
EMU (Eugene)
Cosmicsoul (Jay)
Hrdrvr (Landon)
Don
VAzRacer (Matt)
kwsmith (Wade)
Rodney
Rob
Pick (James)
Sportsman GT/LM
Lil Josh
Lil Josh's Dad
Lincoln
NitroJunkie?
Braden?
High Speed Hobbies
2011.03.08, 10:07 PM
sounds great cant wait, but im still hoping for a later start so i can save on the hotel.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2011.03.09, 06:44 AM
Me too! 11 or 12 would be my vote.
Landon
LET's Go Racing!
2011.03.10, 08:14 AM
Ain'tSoldEm
Please note the way wing height and rear cut out heights are measured: wing has to be no higher than the top of the roof based on a line parallel to the bottom of the chassis and the rear bumper cutout is based on the chassis bottom as well. Set 'em and forget 'em, change tires, ride height, etc... you will stay legal unless you change the body front or side clips. I will have new tech gear at the race but it is easy enough to check with a block, square and ruler.
High Speed Hobbies
2011.03.10, 09:00 AM
For LMP1 I think the R246 Nissan R390 should be allowed, it's in exactly the same vein as the older LM cars.
2011.03.10, 09:22 AM
Ain'tSoldEm
We did have a long discussion about about this body and since it was actually raced in the same full scale class as the Porsche GT1 and the big McLaren that we do allow in our GT class then we really should allow the R390 in GT as well. Notice that the GT rules do allow up to a 102mm wheelbase. We had a similar discussion when the big Mac came out and we put it in GT since it was a 98mm wheelbase. This does allow someone that wants to run the stable 102mm wheelbase in the GT classes the ability to do so, though in our area no one runs the body or the wheelbase in GT at the moment. We do let new racers run their LM cars in the GT classes but as their skills improve they switch over to a legal body. I do though see that PN calls the R390 an LM.
High Speed Hobbies
2011.03.10, 11:43 AM
PN makes their decisions based on the R246 and Kyosho labels though, and we base our decisions on real world racing.
Sounds good about the measuremnt tool! I can't wait to see it. Ive been setting mine with the car on the table. I'll go back and check to make sure I won't have any problems.
Landon
LET's Go Racing!
2011.03.11, 05:49 AM
Ain'tSoldEm
Added race location. Driver's List and Sponsors up soon!
High Speed Hobbies
2011.03.11, 09:38 AM
of both Time and Space
I'll be there. Please put me down for all 3 classes.
2011.03.11, 10:43 AM
Ain'tSoldEm
Started Driver List, bottom of first post.
High Speed Hobbies
2011.03.11, 10:46 AM
Pedro,
Put me down for all three classes.
Thank you.
Andy
LET'sGo Racing
2011.03.11, 11:23 AM
put me down for all 3 as well
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2011.03.11, 06:25 PM
I gotta see some of the CanAm class chassis'. Please...WHoever races CanAm I'd like to see the beast you drive!
*** TOP SECRET MOTORS ***
[FONT="Book Antiqua"]
2011.03.11, 07:35 PM
i'm down for stock and can-am.
collin will be running LM mod and can-am.
2011.03.11, 07:53 PM
Ain'tSoldEm
I am sure we'll get some cool ones, can't wait!
High Speed Hobbies
