2012.10.10, 01:29 PM
11/10/2012 ccc#4
Carolina Cup 2012, Round 4 is going to be held at LET's Go Racing! on November 10th, 2012.
The event will be sponsored by the following people:
Blessed Decor
Chic-Fil-A
Hatley's Home Improvements
LET's Go Racing!
It will be the final round for 2012, and will decide the points standings for the year. Rodney has already earned the title of Champion for this year, with his near perfect record, but second through 5th are very close, and many other positions are yet to be decided. Team High Speed has a significant, but not insurmountable, team advantage. MBMZR will be trying to lock out all the As to try and make a come back!!
Here is the link to the thread with the results.
While this is a competition between two groups, every one is welcome to attend, and any individual at the event have a shot at the individual cup. We welcome any and all to come join us for fun and competition!
We will be running the typical 3 class format featuring, Can Am 2, GT1, and F1. Detailed rules and more information to follow.
RULES
Can Am 2
Chassis: Any 1/28th scale 2WD chassis.
Track Width: 85mm max
Wheel Base: 90-106mm
Body: Atomic VDS (any version), PN Pan Car (any type), Le Mans Prototype or Can-Am style polycarbonate (Lexan) body (open or closed ****pit), Kyosho Le Mans ASC, White Body or similar.
Width: 85mm max.
Length: 200mm max
Height: 60mm max
Wing: No limitation other than must fall within Body Width-Length-Height envelope.
Electronics: Unlimited.
Min Weight: 170g with transponder.
Wheels: Any Mini-Z type wheels, plastic or aluminum.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber Mini-Z type tires (no foam).
Batteries: 4 x AAA NiMh or Alkaline (Lithium based batteries NOT allowed).
Motor: Spec motor designated by the Event.
GT1
Track Width: 80mm max
Wheel Base: 86-102mm
Body: Kyosho ASC, White Body or equivalent (TRP, Iwaver, X-Mod, etc...) hard plastic bodies allowed, excluding LM-LeMans Prototype bodies (See LMP class list) or Can-Am/Pan-type bodies. No thin shell Lexan/polycarbonate bodies allowed. Bodies may be altered for wheelbase but a maximum wheel opening of 31mm measured horizontally must be maintained. Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. Cabin window must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia or bumper maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 70mm max
Wing: All wings original to the body are legal. Aftermarket or non original wings must fit within the confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Batteries: 4 x AAA NiCad, NiMh or Alkaline (Lithium based batteries NOT allowed)
Front: 9 x 22mm max
Rear: 11 x 22mm max
Min Weight: None.
Motor: Any 130 size brushed motor. Brushless not allowed.
F1
Chassis: Kyosho Mini-Z F1 chassis only!
Wheel Base: 130mm only
Body: Kyosho Mini-Z body (ASC or prepared white body) only!
Width: 85mm max.
Length: 210mm max
Height: 50mm max
Wing: No wider than 58mm. Mounted no higher than 45mm.
Min Weight: None.
Wheels: Any Mini-Z Formula 1 type wheels, plastic or aluminum.
Tires: Any Mini-Z Formula 1 rubber or tires.
Batteries: 4aaa NiMh only.
Motor: Any 130 size motor.
Landon
LET's Go Racing!
2012.10.10, 01:30 PM
Drivers list
CA2
Andy
Brad
Brandon
Cade
Collin
Conor
Drake
Eric
John
Michael
Landon
Mike M
Rodney
Terry
GT1
Andy
Brandon
Bryan
Cade
Conor
Drake
Eric
John
Michael
Landon
Mike M
Rodney
Terry
F1
Andy
Brad
Brandon
Conor
Michael
Landon
Rodney
Terry
Landon
LET's Go Racing!
2012.10.10, 04:18 PM
Put me in all races Drake in all unless it is f1 then just 2
MiChAeL
2012.10.10, 08:32 PM
Please put me in for all three classes.
2012.10.25, 02:27 PM
I'm sure you guys knew the rules already, but they are all up and official now I also started the driver's list. Hopefully this will motivate some folks to let me know they are coming
Landon
LET's Go Racing!
2012.10.27, 03:24 PM
put me in on GT1...unless i find a F1
2012.10.29, 07:47 PM
We need longer drivers list or maybe its a good thing for me lol
MiChAeL
2012.10.30, 03:28 PM
Yea, it seems that everyone waits to the last minute to sign up.
Hope all the regulars from HSH are coming, it is always a pleasure to see eveyone.
2012.10.30, 08:41 PM
I was getting my hopes up to have a good finish lol
MiChAeL
2012.10.31, 08:27 AM
Michael....It looks like you and I and a few others have a pretty close race going for points.
It should turn out to be interesting.
2012.10.31, 10:15 AM
I hope my junk will perform not been to good at hsh never have time to work on anymore i guess that is a good thing lol
MiChAeL
2012.10.31, 11:02 AM
Sorry guys, I gonna miss my first Cup race. Just can't make it this time.
You guys race hard and have fun...Go High Speed!!!
Wade
2012.10.31, 12:37 PM
Wade....Sure am sorry to hear that you are not coming, it is always a pleasure to race with you and Josh.
I was also hoping to send a white body with to paint.
Take care and we will see you at the next one.
2012.10.31, 03:16 PM
Just got the PM Wade. It won't be the same without ya! Thanks for the heads up though.
On a more positive note, Grason and John have been by recently and both of them say they will be here for the race! Terry also posted in the other thread he was coming, so there are some names missing off the list that are planning on being here.
Landon
LET's Go Racing!
2012.10.31, 08:11 PM
looks like my schedule cleared up a little, so me and Conor will be there
Rodney
