2013.02.09, 04:14 AM
#31
of both Time and Space
Would be nice to post a link here and in the CC#1 thread about the class rules. Specifically the minimum class weights... Pretty sure Can-Am is unlimited, but don't recall GT1 and 2 minimums!
2013.02.09, 06:35 AM
#32
GT-1 no weight limit. GT-2 175gr I think.
2013.02.09, 06:48 AM
#33
Thanks Mike.
Marwan.....I think you are right, but I can not find the rules, classes, etc and I am pretty sure that Pedro did this.
If we could find them, maybe I could learn how to copy yhem over to the threads.
Mike .... Did I hear you are not making it to the race?
Andy
LET'sGo Racing
2013.02.09, 06:58 AM
#34
pyschopath racing
Grand Touring Class GT2
Chassis: Any 1/28th scale 2WD chassis.
Track Width: 80mm max
Wheel Base: 86-102mm
Body: Kyosho ASC, White Body or equivalent (TRP, Iwaver, X-Mod, etc...) hard plastic bodies allowed, excluding LM-LeMans Prototype bodies (See LMP class list) or Can-Am/Pan-type bodies. No thin shell Lexan/polycarbonate bodies allowed. Bodies may be altered for wheelbase but a maximum wheel opening of 31mm measured horizontally must be maintained. Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. Cabin window must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia or bumper maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 70mm max
Wing: All wings original to the body are legal. Aftermarket or non original wings must fit within the confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Electronics: Stock Mini Z board, Fets unlimited.
Batteries: 4 x AAA NiCad, NiMh or Alkaline (Lithium based batteries NOT allowed)
Wheels: Any Mini-Z type wheels, plastic or aluminum.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber Mini-Z type tires (no foam).
Min Weight: 175g with transponder.
Motor: 70 turn hand out(hand out motors will be returned to race director at end of event.)
2013.02.09, 07:03 AM
#35
pyschopath racing
GT1
Width: 82mm max.
Length: 200mm max
Height: 70mm max
Electronics: Unlimited.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Min Weight: None.
Motor: Any 130 size brushed motor. Brushless not allowed.
Can Am Classes
Track Width: 85mm max
Wheel Base: 90-106mm
Body: Atomic VDS (any version), PN Pan Car (any type), Le Mans Prototype or Can-Am style polycarbonate (Lexan) body (open or closed ****pit), Kyosho Le Mans ASC, White Body or similar.
Width: 85mm max.
Length: 200mm max
Height: 60mm max
Wing: No limitation other than must fall within Body Width-Length-Height envelope.
CanAm1
Min Weight: None.
Front: 11 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber or foam tires.
Batteries: 7.4V max. (Lithium based allowed).
Motor: Any 130 size motor. Brushless allowed.
2013.02.09, 07:11 AM
#36
Originally Posted by Daddy Rabbit
Thanks Mike.
Afirmative. Current budget constraints will keep me close to home indefinitely.
2013.02.09, 07:37 AM
#37
Sorry to hear that Mike....You will be missed.
Andy
LET'sGo Racing
2013.02.09, 08:07 AM
#38
Thanks Mike.
Oops! I probably should have posted what I did in the CC#1 thread here. Anyway, it would be nice to have a Rules thread under Carolina Cup for all to reference as needed and for it to be a sticky.
2013.02.09, 09:53 AM
#39
^ you sure are needy. I think we need to change your handle to Nancy. Lol
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2013.02.09, 11:55 AM
#40
Whoooooo you callin Nancy?
Andy
LET'sGo Racing
2013.02.09, 01:44 PM
#41
Good one Chad, but let's see who's acting like a girl on March 2nd
Oh, and FYI my female name is Thelma
2013.02.09, 02:57 PM
#42
Thelma and Millie. Nice couple.
2013.02.09, 03:14 PM
#43
pyschopath racing
Oops! I probably should have posted what I did in the CC#1 thread here. Anyway, it would be nice to have a Rules thread under Carolina Cup for all to reference as needed and for it to be a sticky. (Marwan)
ive posted a CC rules thread hopefully everyone will see the no discussion here phrase , i think i covered every class in the Carolina Cup
hope this helps everyone
2013.02.09, 04:13 PM
#44
Albert....Good job on the CCC Rules Thread.
Thanks.
Andy
LET'sGo Racing
2013.02.10, 05:58 AM
#45
2013 CCC Race #2
Has there anymore talk about the date for Race #2 in May?
Andy
LET'sGo Racing
