2013.03.15, 04:03 PM
pyschopath racing
CCC race # 2 april 27,2013
.will be runnig GT70/LM70/CanAm1
Entry fee will be 20 dollars 1st class,10 dollars 2nd class,10 dollars 3rd class
races will begin at or around 11 am on the 27th
hope to see everyone
[B]Grand Touring Classes
[/B]
Chassis: Any 1/28th scale 2WD chassis.
Track Width: 80mm max
Wheel Base: 86-102mm
Body: Kyosho ASC, White Body or equivalent (TRP, Iwaver, X-Mod, etc...) hard plastic bodies allowed, excluding LM-LeMans Prototype bodies (See LMP class list) or Can-Am/Pan-type bodies. No thin shell Lexan/polycarbonate bodies allowed. Bodies may be altered for wheelbase but a maximum wheel opening of 31mm measured horizontally must be maintained. Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. Cabin window must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia or bumper maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 70mm max
Wing: All wings original to the body are legal. Aftermarket or non original wings must fit within the confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Electronics: Unlimited.
4 x AAA NiCad, NiMh or Alkaline (NiZn or Lithium based batteries NOT allowed).
Wheels: Any Mini-Z type wheels, plastic or aluminum.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber Mini-Z type tires (no foam).
GT2
Min Weight: 175g with transponder.
Motor: Spec motor designated by the Event.
[B]Le Mans Prototype Classes
[/B]
Wheel Base: 102mm only
Body: Kyosho LM-LeMans Prototype ASC or White Body only:
Porsche 962, any version.
Mazda 787, any version.
Sauber C9, any version.
Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. A maximum wheel opening of 32mm measured horizontally must be maintained. Cabin windows must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 60mm max
Wing: All wings original to the body are legal. Aftermarket or non-original wings must fit within confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
LMP2
Front: 9 x 18.5mm max
Rear: 11 x 20mm max
Tires: Kyosho LM specific tires only.
Can Am Classes
Track Width: 85mm max
Wheel Base: 90-106mm
Body: Atomic VDS (any version), PN Pan Car (any type), Le Mans Prototype or Can-Am style polycarbonate (Lexan) body (open or closed ****pit), Kyosho Le Mans ASC, White Body or similar.
Width: 85mm max.
Length: 200mm max
Height: 60mm max
Wing: No limitation other than must fall within Body Width-Length-Height envelope.
[B]CanAm1[/B]
Min Weight: None.
Front: 11 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber or foam tires.
Batteries: 7.4V max. (Lithium based allowed).
Motor: Any 130 size motor. Brushless allowed.
2013.03.15, 04:05 PM
pyschopath racing
Drivers list
GT70
albert
wade
rodney
landon
pedro
chad
Marwan
andy
bryan
dwight
tommy
josh
Ray
scott
john
don
CANAM1
albert
wade
rodney
landon
pedro
chad
Marwan
andy
bryan
dwight
tommy
josh
scott
don
LM70
albert
wade
rodney
landon
pedro
chad
Marwan
andy
bryan
dwight
josh
Ray
scott
don
2013.03.15, 04:12 PM
Ain'tSoldEm
All 3 for me.
High Speed Hobbies
2013.03.15, 04:17 PM
All 3 for me as well
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2013.03.15, 04:39 PM
of both Time and Space
Mee three
2013.03.15, 06:44 PM
Bryan says he is trying for all three as well! I think we are going to have to come up with something creative to get him into all three though.
Landon
LET's Go Racing!
2013.03.15, 07:01 PM
All three for me.
Andy
LET'sGo Racing
2013.03.18, 05:50 AM
Hey, let's get this thread going and active, the more this stays on the forum, the more people will see it.
Remember people this is where you sign up for the race on April 27th.
I see that are some folks that talked about coming but have not signed up yet.
Andy
LET'sGo Racing
2013.03.18, 08:44 AM
i'm just a solid body from being in LM..trying to figure out if i'm getting another body or not
2013.03.18, 09:19 AM
Let me know what you need.
2013.03.18, 10:00 AM
Mike....I don't see you and Cade on the list yet, are you going to make this one?
I look forward to trading paint with you on the short track.
Andy
LET'sGo Racing
2013.03.21, 11:19 AM
pyschopath racing
wheres everyone at awful quite in here anyone else coming
2013.03.21, 11:23 AM
i'm here..just crossing my fingers that everything works out for me to make this and the rest of the CCC races. i need all the points i can right now
i should be good just trying to make some decisions right now. thanks though
2013.03.21, 01:00 PM
Maryland
Hello this is Dwight from Maryland can I have the track address so i can come down that weekend.
2013.03.21, 01:03 PM
Here is the contact info that is on their website. It should all be current
High Speed Hobbies
2510 Hwy 29 S.
China Grove, NC 28023
(800) 357-5298
mailto: info@hshobbies.com
Are you going to bring any other fellow RMZR down with you?
Landon
LET's Go Racing!
