Old 2018.10.26, 01:16 PM   #16
mugler
mugler's Avatar
Originally Posted by arch2b View Post
That reconfigurable mount is a real treasure hunt to figure out... you go to one part with reference to another, and another, and another... I would assume you could buy either the 94mm or 98-100mm pod kit (the latter is the only one in stock) and then buy the bottom plate and motor mount arm? I've never run this setup for 90mm and would be interested in trying.
Exactly right and as bobbyz mentioned part number for bottom plate is mr2996cf4 and an RM motor mount ( blue version MR2999RB). with the smaller diameter brushless motor you want to mount the motor mount below the carbon fiber upper plate for an additional 1.75mm drop in motor position for super low CG. some shaving of parts will be necessary though but if your going for gold medal performance it's well worth it. same lower motor mount trick works with 94mm reconfigurable, simply the fastest 94 mount out there. & yes this is faster than the squished MM.
Old 2018.10.26, 02:10 PM   #17
HaCo
02-Racer
HaCo's Avatar
Very nice man!
Porsche 911 GT1 Rohr Custom andrewp Custom Bodies 4 2017.04.08 11:02 PM
Gulf Porsche GT1 Dusty Weasle Custom Bodies 10 2013.02.12 09:54 AM
Porsche 911 GT1 #99 Old Crow Custom Bodies 5 2010.09.20 09:00 PM
FS: Porsche 911 GT1 No. 25 LM 1996 pinoyboy Mini-Z Marketplace 0 2009.12.22 05:08 PM
MR-02 MM Porsche 911 GT1 Evo TNB Mini-Z Racer MR-02 9 2004.07.05 04:20 PM
