Old 2012.07.04, 04:47 PM   #211
xX350zBoYXx
xX350zBoYXx's Avatar
Not sure if anyone has posted this since I haven't been on in quite some time but for the lucky few of us that have an xmods impreza, it has perfect fitment on the AWD if you have the atomic rear end without that little bar going up at a 45° angle. Set-up is have the chassis set to the hole farther from the engine (94mm setting hole?). Have your xmods evolution rear clip on the impreza. You're going to have to shave the bottom of it just so it doesn't scrape. For the front clip use the 2007 Impreza Sti clip from the mini-z awd body. Then just put the front in the correct slot and snap the rear clip down to the end of the chassis. If you run med or soft springs, the car looks a tad lowered too.
日本語
xX350zBoYXx is offline   Reply With Quote
Old 2012.12.02, 07:17 AM   #212
kryten
kryten's Avatar
I know these have been done before,but there isn't one in this thread....
106mm wheelbase,although standard z wheels look too small. (still 102mm in the pic)
strips down easily too
Add some Overland wheels,and it starts to look right.
Old 2012.12.02, 10:20 AM   #213
Tinytacohead
Tinytacohead's Avatar
Thumbs up
Looking good p23si. I say keep posting here until somebody suggests otherwise? (IMO anywho)
Thanks for the info xX350zBoYXx. I've been looking towards possibly getting an Impreza body for some time, though have always wanted one a little different than what Kyosho provides, scheme wise.. I may have to check out that one in particular!
That's pretty pimp kryten! I wonder if there're any trailers out there that'd be mate-able, size & functionality wise. When I was a youngin', my Dad/Grandpa started a tradition of giving us boys those little Hess static display models. (with working lights & whatnot) I have one that's got a trailer which came with a rev-ip style, (Porsche I believe), race car on it. (which got played with until death, long long ago ) It's high up on a shelf & thus I've not yet retrieved it to find out, but it looks as though a Mini-Z would fit perfectly on the back, both physically & possibly scale wise. For ages I've considered making it a powered model of sorts, and just now I had the brain-flash of maybe doing up a matching Z body scheme. (or having one of you better skilled folks do one for me ) Maybe it's time to get it down & have a closer look! (I'd probably get a better example off Ebay for a final product, as it's white & mine's old enough to be yellowing a tad/showing its age)
| MA-010 GTR32 | Nitro Rustler | Nitro Hawk | Mini Inferno 09B | Tamiya Chevy S10 | Micro-T |
Tinytacohead is offline   Reply With Quote
Old 2012.12.02, 02:06 PM   #214
NoBrainer
NoBrainer's Avatar
Thanks Kryten.
Do you know if all the truck body's are 106mm?
Or are some body's shorter?
Old 2012.12.03, 08:57 AM   #215
kyoshosan
kyoshosan's Avatar
Hi Kryten,
Nice idea on the overland wheels! I'm about to start a similar project, will use your idea :-) keep us posted on your progress.
kyoshosan is offline   Reply With Quote
Old 2012.12.03, 09:32 AM   #216
i tried overland wheels on racers before and in the past, the motor/car ran very hot as a result. this was back in the days of AM cars though.
Old 2012.12.03, 10:26 AM   #217
kryten
kryten's Avatar
Originally Posted by NoBrainer View Post
Thanks Kryten.
I think they are all different,my friend is working on the Atego,and also has the MAN too,so i'll get measurements.
I will say the bull nose is easier to mount than the atego from what we have found so far.
I will update as we go
Originally Posted by kyoshosan View Post
Hi Kryten,
Thanks i peeled off one of the trucks std tyres and they fit the same as OL tyres,BING! the light bulb appeared lol
I'll test a few different motors,though it will probably end up with a 70t fitted.
Old 2015.05.29, 06:20 PM   #218
golgi
Are there any plastic models/kits out there with an Alfa Romeo Giulia Sprint body that fits a 98mm wheelbase? I'd like to put one on my Atomic AMZ.
UPDATE- never mind, I just looked through older posts and see that Bodom did exactly what I want!
golgi is offline   Reply With Quote
Old 2020.09.14, 01:16 PM   #219
jasonak
Is there a similar thread like this using 1/24 Slot cars ?
If anyone comes across this
this guy is spot on 102 mm and width is good also Ferrari 512
https://www.carreraslots.com/slot-car/23899.html
This Audi R8 was way bigger,,I mean you can make anything work but its pretty wide and longer than my 102
https://www.carreraslots.com/slot-car/23840.html
jasonak is offline   Reply With Quote
The Perfect Mesh... Programmers Mini-Z AWD MA-010, MA-015 8 2008.03.05 05:13 AM
FS: Higly modded MR-02 Enzo - Perfect condition faydoiinspire Mini-Z Marketplace 9 2007.11.26 10:31 PM
XMod rims fits on a AWD MA010 MiniZ ... GGTuning.com Mini-Z AWD MA-010, MA-015 9 2006.06.18 10:30 AM
Lexan Saleen Body fits well AllAmericanDan Custom Bodies 0 2003.08.24 10:57 PM
The Perfect Antenna ScottMcLeod Mini-Z Science 5 2002.08.25 11:05 AM
