Features
-3mm over size bearing for greater bearing stiffness.
-Axel Hub clamps both bearing inner races tight against axle to eliminate free play between bearing inner race and axle.
-Majority of the front wheel free play will be eliminated with use of over size 3mm bearing and by clamping of bearing inner races.
-Bearing spacer shims included to accommodate different bearing spacing on most rims.
-Wheel Offset Spacers to increase wheel offset. Increase offset by 0, 0. 5 or 1 mm for fine offset adjustments.
Spec
Use for Mini-Z
MR01, MR02, MR03, F1. all Mini-Z 2WD front knuckles.
Packing Includes
2 x Axle Hub
2 x Bearing Spacer (Orange)
2 x 0.5mm Wheel Offset Spacer (Blue)
4 x 3mmx6mmx2.5mm Ball Bearing
4 x M3 0.2mm Shims (700502)
Requirements
4.5mm Lock Nut Driver
M3 x 0.2mm shims may be need more, depends on difference brand of the wheel (700502)
Awesome good deal. Glad I waited a couple of minutes before ordering Order placed now! Have a couple of customers who will be happy to get theirs cheaper than I told them!
Wow this seems like a great part for getting rid of the slop we have in our front wheels, without worrying about tightening the nut too hard... at a good price too since it replaces both the nuts and the front bearings.
