Old 2015.02.16, 04:14 PM   #1
Tapir
Guest
Posts: n/a
Brushless stock class
What are the plans for brushless stock?
About time this gets done now since Kyosho discontinues the brushed cars.
Enlighten us.
Old 2015.02.16, 09:40 PM   #2
DMALMAD
DMALMAD's Avatar
brushed cars are not dicontinued just the asf. And brushed cars are the still the standard seeing as the brushless is not really as good. There really isn't a viable stock brushless motor because even with the lower kv motors you can gear them to get simmilar lap times as the higher kv motor. Not the same but close enough. I don't see pn making stock cass brushless until they either come out with their own brushless system or kyosho releases a decent sensored system. Just my two cents.
Old 2015.02.23, 11:25 PM   #3
Jshwaa
Jshwaa's Avatar
Question about the brushless' shortcomings...
Can you describe what about the operation that is undesirable, specifically? Not enough levels of speed control? Does it seem like the controller is chasing your speed command? I'm curious as I've yet to actually mess around with brushless anything, let alone mini-z's.
Old 2015.02.24, 01:03 AM   #4
yasuji
PN RacingTEAM Driver
yasuji's Avatar
We have been exploring a 70t speed brushless motor.... Things are looking good on that front... However... Some feel that it is not fair to mix the stock class with a brushless equivalent... Feeling that there will be an advantage... Or the pressure to make an additional investment to the brushless set up... Imo think it will be a great advancement...
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
Old 2015.02.24, 07:40 AM   #5
DMALMAD
DMALMAD's Avatar
Unless it is a sensored system there will be no bennefit of runnung brushless. Technically if a brushless motor has the same power as a brushed motor than the brushed motor will yeild fatser times. This is because the current brushless system avialabe are basically on off swiches. They have a very limmited powerband and the overall feel is not smooth enough, nor is there enough drag break. On an extremely easy and open layout like that of the PNWC this difference may be less. The only advantage of the brushless motors is there is less variaton from motor to motor which is why I say only if, later on, a sensored board that you can drop into you car becomes avialable should brushless motors be used in stock class. Personally I don't like any of the brushless motors for any racing whether mod or stock and therefore don't really see their bennefit as I look for the best performer when it comes to lap times. Usually the fastest car down the straightway is not the car setting hot laps or winning races. In stock having a faster motor is a huge advantage but the fastest guys can win with the slowest motor
Route 241 Raceway at Kyosho Tim Johnson Route 241 Raceway, Lake Forest CA 399 2015.01.13 02:49 PM
Ice Melter Mini-Z Race Feb. 2013 (Wyoming) briankstan Events 35 2013.02.19 12:03 PM
MHS 2012 PN Regional!! ruf993 Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 58 2010.10.29 10:17 PM
My Suggestion for Next Years Racing Format JuniorWKR PN Racing World Cup 43 2009.11.04 10:05 PM
ics setting for stock class B-main Miscellaneous Discussion 0 2009.08.05 06:06 PM
