This was a body I did a few years back. These are new photobucket pictures. I tryed a few angles of the inside to show the mounts. I just unscrewed the rear tab to locate the body on the chassis with the molded in tab mount sitting on the motor pod. The side clips are just T bar stock 6mm x 6mm, cut and CA'ed in place. I used thick CA with an activator, These things are solid and will not move. The side skirts are also bonded in place as well. The side clips are fixed to that. The last thing I did was cut away the original tab mount. It is alot like Byebye's Evo, just that I made my own side clips. This is a point of no return mod here. Enough chatter, on with the pictures.
Here I was doing some ballancing, to see how much weight is in the nose area. One of these shots I have removed eight screws from the nose to see the difference. Yes, I did finally paint the front facia white.
