Old 2011.11.30, 03:11 PM   #16
skyler
skyler's Avatar
90mm Setup
Hi Sai, Would you mind posting more pics of your 90mm setup? Thanks.
Old 2011.12.04, 06:17 PM   #17
SaiTam
Are you Fetted?
SaiTam's Avatar
Audi TT Body. 0/0 offset. 10 AW Rear / worn 10dV-groove or 20d V-groove front tire. Carpet Racing.
Front: Yellow springs; .5mm knuckles with enhanced larger bearing axles; N2 tower bar; Titanium Kingpin. Reverse kingpin/Alu. Lower Arm will go on soon. Just wanted to test how far I could push stock suspension setup in Narrow.
Rear: AR-265 90mm Mount. Pink V.3 spring. Atomic X-flex Stage 1 T-plate. -1mm Narrow offset Ball Diff.
Video -- TQ + winner: http://www.youtube.com/watch?v=qtzxJ...&feature=g-upl
Old 2011.12.04, 09:10 PM   #18
Skv012a
Skv012a's Avatar
And correct me if I'm wrong here, but short and narrow setups, first and foremost, do not allow you to push the car nearly as hard through the corners as wide setups; so, you have to drive it MUCH more carefully and technically to avoid rolling.
I think adding some weight (metal rods) to the belly gaps between battery slots would also help overall. I'm personally trying to see if using aluminum wheels also helps lower and spread the weight around where these cars need it the most.
New site.
Old 2011.12.04, 09:53 PM   #19
SaiTam
Are you Fetted?
SaiTam's Avatar
On Carpet it is different. I could push my narrow as hard as I wanted. Notice my car is not lowered with 20mm wheels all around. Not one hatchback traction roll in the race I believe. Check video again.
Old 2011.12.05, 01:38 PM   #20
Skv012a
Skv012a's Avatar
Then, I'll correct my train of thought towards RCP. I still have absolutely NO carpet experience, but definitely want to try it sometime.
New site.
Old 2011.12.08, 08:41 AM   #21
rajiex
rajiex's Avatar
Sai,
on my 90 Atomic mount, the discs barely make contact to the damper plate.. Should I shim below the mounting plate and top cover or shim between the spring and arm so that the disc makes contact..
Raj
Action RC2]
  • MR-03 94MM Ferrari Modena
  • MR-03 94MM Nissan 350Z
  • MR-03 90MM Ferrari 355
  • MR-03 98MM Ferrari 599
  • MR-02 98MM Mosler
  • MR-02 102MM Mazda 787B
  • MA-10 94 Chevy Corvette
  • MA-10 94 Toyota Supra (Drifter)
  • MF-015 Ferrari
rajiex is offline   Reply With Quote
Old 2011.12.08, 09:11 AM   #22
Atomic-USA
Customer/dealer support
Yes, check my first photo above you'll see I put shims in mine too.
www.rcatomic.com
Old 2011.12.08, 06:30 PM   #23
Skv012a
Skv012a's Avatar
My disk isn't horribly pressed against the plate, but that fairly loose feel really does its magic.
New site.
Old 2011.12.09, 05:34 AM   #24
rajiex
rajiex's Avatar
That did the trick, keeps the rear planted and eliminated a lot of chatter.
Thanks,=..
Raj
Action RC2]
  • MR-02 98MM Mosler
  • MF-015 Ferrari
Old 2013.08.16, 09:15 PM   #25
i'm thinking about getting the kyosho CE28N wheels which are 17mm front and i assume standard 20mm rear. does this much smaller diameter front wheel make a noticeable difference? i am currently running the atomic S6 19mm front and 20mm rear. i prefer the smaller diameter front wheels just to give a fraction better tire clearance on the inside of the shell. i always seem to be scrubbing something with 20mm wheels.
Old 2015.03.29, 03:23 PM   #26
anyone able to get the mr-02 atomic 90mm rm damper kit to work with 90mm mr-03? i have the damper, rm t plate and motor mount but nothing is lining up at the t plate holes for 90mm.
Old 2015.03.29, 06:52 PM   #27
Are you using an rm or mm t-plate? I used both the rm and mm 90mm config on an mr03 for a short time without much complication. Are you using rm or mm mount? If you can post a pic of the top and bottom view that would help diagnose the issue...
Old 2015.03.29, 07:53 PM   #28
RM t plate, RM atomic motor mount. can';t explain why the damper posts just are not aligning right. they are about 4mm to far back. maybe the newer version motor mount isn't the same as the original that was coordinated with the damper.
Old 2015.03.29, 08:36 PM   #29
byebye
byebye's Avatar
Got pics? I'm not picturing it.
Old 2015.04.05, 10:33 AM   #30
here... wrong RM mount?
Brian's RCX 2011 Final Setup color01 Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 35 2017.02.19 06:38 PM
PN Tri-damper + 90MM mount = Bi-damper cooper! doug01n Setups 1 2010.06.15 08:21 AM
FS - ASF mr-02 loaded PN and Atmoic and 90mm rolling chassis davskee Mini-Z Marketplace 6 2009.09.29 04:04 PM
90mm MA-010 setup im8im8 Mini-Z AWD MA-010, MA-015 10 2009.06.02 11:05 AM
Mini Z Setup and Offset sheets RyukoTR Setups 0 2007.08.25 01:39 PM
