Old 2013.02.20, 02:13 PM   #1
seanminiz
RCP Issues
Just want to know if you guys know of a way to flatten out RCP that has slight bends in it. I have a track in my office warehouse... and on some of the inside radius and corner pieces have a dome shape to them. I have alot more of track, i was hoping to flatten the pieces out that are in place....
Its sad that i have all this track and nobody to race with. I get about 100-150 laps a day practice in.... but nobody to race with.
seanminiz is offline   Reply With Quote
Old 2013.02.20, 02:23 PM   #2
Traveler
of both Time and Space
Traveler's Avatar
Sweet track! Where is it?
Maybe put something heavy like books on the spots that are bowed up when the track is not in use? Or they may flatten out on their own over time.
Old 2013.02.20, 02:25 PM   #3
briankstan
briankstan's Avatar
Welcome to the forums. I would say that with the track laying out it should flatten out by itself. you could manually roll them them in the opposite direction as the bump to help with the process. if you put something heavy on it make sure it's flat or it will leave impressions. and they will take longer to finally go away.
Nice track, where are you located?
Old 2013.02.20, 02:34 PM   #4
imxlr8ed
imxlr8ed's Avatar
Direct sunlight straightens them out pretty quickly too!
Ditto on location... ?
http://www.howfastareyou.com
SUPPORT LBR!!!
(Local Basement Racing)
Old 2013.02.20, 02:37 PM   #5
seanminiz
Track
The track is in houston, tx.
I bought it from some of the old local racers... I have a ton extra... alot of 90's oustide and inside and 45 deg..
Thanks for the help. It is flattening some... but i notice with the temperature changes we are seeing in texas over the past month the track seems to be better or flatter when its warm.. when its cold.... not so much.
Old 2013.02.20, 03:39 PM   #6
Sammich
probably on the warmer days you may want to vaccuum and then place as was said some books on the parts that arent flat..should help out
Old 2013.02.24, 10:30 AM   #7
a1m80t
I live in the Houston area, perhaps we can organize something? I can probably pull 2-3 racers and I have the Core laptimmer (and know how to make it work with concrete)
a1m80t is offline   Reply With Quote
Old 2013.02.24, 10:58 AM   #8
warm temp and or sunlight will help them flatten out. the material is temperature and humidity sensitive. in general they will flatten out by themselves unless compressed by something else. as suggested, manipulating the tiles to work bends out will work to an extent as well.
do not lay heavy objects on tiles for long periods of time. it can leave semi-permanent indention's in the surface. i had to put a step ladder on my track once as still waiting for those indention's to go away and that was maybe 10 minutes with me on the ladder. they have gotten much better over time but still present.
Old 2013.02.25, 01:57 PM   #9
monkeyZ
The Race Dictator!
monkeyZ's Avatar
Give the track a little shuffle. This sounds funny, but usually the track is actually bunching up on you. If you notice that there isn't a 1 wall width space between any of the sections that run parallel to one another then the track is actually not sitting flat. My daughter uses my track as a "RACE TRACK!" to run around on all the time and she slides the pieces together and I see the bubbles especially in the wide inside corners.
So really just go to each side of the track that you can access and put your hands a few tiles apart and shuffle the track side to side and it will lay back down flat.
I have thought about cutting some small wood 2x2's to put between the turns and straights to stop the track from sliding on the carpet...
monkeyZ is offline   Reply With Quote
Bringing back an idea to the table for RCP to go Carpet OPtion :) Felix2010 RCP Tracks 6 2011.06.26 09:59 PM
RCP International Shipping Mrs Mini-Z Promotions 0 2010.01.08 03:51 PM
shop.tinyrc.com - On the MZR Forums & RCP International Shipping Mrs Mini-Z Newsletters 0 2010.01.08 03:43 PM
RCP West Coast Challenge at RCX RCPMini-z Tracks and GTGs 90 2008.06.28 12:32 PM
