Old 2010.11.18, 03:21 AM   #1
vesahyp
vesahyp's Avatar
Suspension arms
Hi,
I managed to break the left top half of the front suspension arm (where the kingpin is connected). Obviously i'll try and glue it back on for a quick fix, but what are my real options here?
The WTF that replaces the suspension arms altogether? What are tower bars for, can i use one to replace the top half of the arms? One option ofcourse is a whole new chassis.
I'm a bit lost here to be honest and would appreciate any insights, thanks!
vesahyp is offline   Reply With Quote
Old 2010.11.18, 04:30 AM   #2
color01
color01's Avatar
Standard-width tower bars will suitably replace both your upper suspension arms -- they won't ever break again so you'll be fine from there on out.
The WTF front end actually widens the front end in total, so you need to install all three pieces to get the correct geometry out of the kit. It works great for the 02 though, the WTF2 has a kingpin inclination that helps reduce suspension stiction under cornering loads.
Brian Ma
Greyscale RC
PN Racing | My TinyRC Blog
Old 2010.12.07, 03:23 PM   #3
dvsstrike
The name is Tim
dvsstrike's Avatar
depends on what body you run. I would just run the wtf most of the time. its a great product.
dvsstrike is offline   Reply With Quote
PN Double A-Arm Front Suspension benmlee PN Racing 382 2019.01.14 06:27 PM
About tweak and how to perfect balance your 4wd suspension. eztuner12 Mini-Z AWD MA-010, MA-015 7 2011.04.15 03:56 PM
New Reflex Front Arms and Multi Option Rear Suspension CristianTabush New Products 30 2010.09.23 03:41 PM
MR-01, MR-01F, MR-02mm (enzo), MR-02rm (nsx), OL, Monster, F1 TNB Autoscales, Bodies, Cars and Drivers 47 2004.08.22 04:29 PM
Sticky front suspension chelboed Mini-Z Overland MV-01 3 2003.07.15 05:32 PM
