Old 2017.01.22, 10:06 AM   #1
HugoW
What stock / silver can motor has mounting holes?
Hi,
at our track one is obliged to use the stock silver can motor that comes with the kit. We are allowed to remove the yellow thing (fuse?) This motor choice thoroughly limits the choice of alloy rear pods. What spec is the stock silver can and is there a motor with similar spec that does feature these holes? I have a PN 70T, but I think that performs better.
Cheers,
Hugo
HugoW is offline   Reply With Quote
Old 2017.01.22, 06:30 PM   #2
Aiden M
The stock motor is 80T. Not sure if there are other aftermarket 80T motors. You could drill the holes yourself if you want to install it in an aftermarket rear pod.
Aiden M is offline   Reply With Quote
Old 2017.01.23, 12:01 PM   #3
TeeSquared
Redline
I thought the stock Kyosho motor was 70T.
I would expect the PN motor to perform a little better with the same turns as it uses neo magnets. In terms of hop ups though, don't be afraid of using plastic on your cars. Lots of people will tell you that you NEED alloy pods/suspension to have a competitive car, but for club racing this simply isn't true. For 70T racing, all you really need is bearings and a T-plate (and tires to suit the track, of course) and you can be very competitive at the club level.
Old 2017.01.23, 03:00 PM   #4
I am pretty certain that the PN 70g does not use neo magnets. I believe that the wire is a larger gauge on the PN in comparison, with slightly thicker ferrite magnets. The commutator on the PN motor is also a larger diameter, with a softer more conductive brush.
This all gives a little more low end torque but somewhat similar rpm.
The PN 70t is the closest motor that you will find compared to the Kyosho stock bushing motor. The PN 80t would be a little closer, but I don't think it is available anymore.
Anyone not using the stock silver springs on their Atomic disk damper? builthatch Mini-Z Racer MR-02 0 2006.04.24 01:19 PM
Best all around Stock Motor to use without Fet upgrade Warchild Motor Tech 37 2005.11.07 08:33 AM
A new Stock Car class will be starting this fall at CP Mini RC Raceway Blackno3 CP Mini RC Raceway, NY 58 2004.10.27 08:23 PM
remote and stock parts for sale BoyWonder Miscellaneous Discussion 0 2003.03.10 08:02 PM
Stock Class Racing DAMZer Off-Topic 13 2002.08.29 04:57 PM
