2007.02.27, 10:22 AM
Calling all Transmitter experts!
I need volunteers!
With this new transmitter forum I'd like to get a good list going of all the transmitters fully compatible with the Kyosho Mini-z. Preferably a description as well. You can even pull descriptions right from the manufactureres website.
Arch2b did an awesome job with the different chassis and such. Lets see if we can do this one for him!
Post up the info and I'll cut, paste, and sticky
- Byebye
2007.02.27, 10:35 AM
good idea! thanks
be sure to quote as much of the manufacturer information as possible. embed and ATTACH any images/information necessary.
byebye, when the pasted completed thread is done, be sure to attach any files as well. the reason why i prefer files are attached as well as embed is they are often lost on other websites or if the product gets dinscontinued they often take the page down which reults in broken links. attaching files ensures long term reliability of the files.
2007.02.27, 12:04 PM
Team Nomadio 007
JR XR2
Transmitter Features
• Two Channels
• AM modulation
• Easy-to-read LCD graphics display
• Two model memory
• Three-digit model name entry
• Electronic digital trim levers for throttle and steering
• Two assignable electronic grip levers
• Direct display trim function
• Servo reversing
• Sub-trim
• Steering dual rate
• Steering endpoint adjustment
(two points — left and right)
• Brake/throttle point adjustment
• Low battery alarm
• Plug-in crystals
• Charge jack receptacle (rechargeable batteries
not included, order JRPB958)
Model number XR-2
Encoder 2-channel computer system
RF output 27/75 MHz
Modulation AM modulation
Output power 195.0 Mw
Current drain 150 mA
Power source 1.2V x 8 dry cell
(1.2V × 8 NiCad
600 mAh optional)
Output pulse 1000-2000 (1500 neutral)
Full manual available at: http://www.jrradios.com/ProdInfo/Fil...127-manual.pdf
My current R/C's: JConcepts BJ4, AE T3 Factory Team, PRP XR80, Losi Mini-LST
Proud user of Nomadio radio systems.
2007.02.27, 12:08 PM
Team Nomadio 007
JR XR2i
Transmitter
• 2 channels
• AM modulation
• 2-model memory
• 3-character model name entry
• Assignable electronic grip lever
• Servo reversing
• Sub-trim
• Steering dual-rate
• Steering end-point adjustment
(two points: left and right)
• Brake/throttle end-point adjustment
• Low-battery alarm
• Plug-in crystals
• Charge jack receptacle (rechargeable batteries not
included; order JRPB958)
Model number XR2i
RF output 27MHz/75MHz
Modulation AM
Output power 195mW
Current Drain 150mA
Power source 1.5V x 8 dry cell
(1.2V x 8 Ni-Cd optional)
Output pulse 1000–2000 (1500 neutral)
Full manual available at: http://www.jrradios.com/ProdInfo/Fil...275-manual.pdf
2007.02.27, 12:21 PM
That's what I'm talking about! I went to Ko-propo and they didn't have all that info. I'll have to go to maybe a reseller site and get the info and pics there.
Goodjob Tzero
-Byebye
2007.02.27, 12:28 PM
Team Nomadio 007
Futaba 2PL
* Digital Throttle/Steering Trim Levers- For fine adjustments at the neutral positions either left or right.
* Easy to read LCD Screen.
* Steering Dual Rate Lever- Adjust the steering travel while cornering. Add steering for understeering or take away steering for oversteering.
* Low Battery Alarm below 8.5V
* Model Reset- Resets the memory to Manufactures settings.
* Servo Reversing (Throttle/Steering)- Reverses the servos operating rotation (Normal or Reverse)
* Throttle/Steering End Point Adjustment (EPA)- Limits the servo movement or travel to the left or right. Each side can be adjusted independently.
* ABS (Antilock Braking System)- Antilock braking by pulsing the brakes on and off rapidly. Can be set for Fast, Mild or Slow pulsing.
* Model Name- Provides 3-Character name for each of the 10 models stored for easy selection.
* Model Memory- Capable of storing 10 models with all the settings for each model.
Full manual available at: http://manuals.hobbico.com/fut/2pl-manual.pdf
2007.02.27, 12:31 PM
i've also started threads for this for chargers as well. it would be nice to get them for batteries. i think we could use this kind of info in just about all the forum sections. i just need to find someone willing to do the work for the battery/charger forum.
byebye, i assume after you compile the info in a thread you'll close and sticky it? maybe do one tx per post?
this is going to be an awsome addtion to this forum!
2007.02.27, 12:38 PM
Team Nomadio 007
Futaba 3PK/3PKS with use of Mini-Z Module
Features
* Large, backlit LCD screen with adjustable contrast and 128 x 64 resolution.
* "Direct Select" — single-button access to 8 pre-assigned functions
* Choice of "New Driver", "Race-Ready", "Big" or "Expert" menus that offer easier programming for sport drivers and more advanced programming levels for competitors
* Adjuster feature that restores compromised settings to Factory Default
* Assignable switch and dial functions
* Two programmable mixes for complex custom setups
* Digital trims and dials with automatic electronic memory
* Subtrims, servo reversing and EPA on all channels
* Failsafe and battery failsafe
* Easy conversion to right- or left-hand use
* Double dual rates, exponential and adjustable servo speed
* Up/Down, lap and system timers
* Direct Servo Control (DSC)*
* All this, in a system that weighs only 29 ounces!
Transmitter T3PK (Pistol, 3 channels)
Operating system: FM/PCM1024/HRS
Transmitting frequency: 27, 75 MHz bands*
Modulation: FM/PPM, HRS-FM or PCM1024, switchable
Power supply: 9.6V NT8F700B NiCd battery
Current drain: 250 mA or less
Full Manual available at: http://manuals.hobbico.com/fut/3pk-manual.pdf
2007.02.28, 12:40 AM
Airtronics MX-A 3ch
Digital Trim indicators (throttle and steering)
Battery gauge and voltage display
Dual Rate Steering
EPA Steering, Throttle, AUX
ARC (Adjustable exponential) Steering, Throttle
Modle memory - 5
Sub-Trim Steering, Throttle
Servo Rev Steering, Throttle
Audio On/Off
Adjustable throttle trigger position
Manual:
http://www.airtronics.net/MX-3%20Manual%20Web.pdf
EX-1 Mars & Mars-R
Mars-R has super HSR circuit that is 33% and up to 40% faster than Mars - Both radio have same functions.
Steering Functions: Travel / Balance / Speed (1~2Way) / Curve / Center Trim / Sub Trim / Trim Rate / Reverse / Punch
Throttle Functions: High Point / Brake / Curve / Punch / Speed (1~3Way) / Acceleration / Active Brake System (ABS) / Preset / Automatic Start / Sub Trim / Trim Rate / Reverse
Timer Functions: Up Timer / Lap Timer / Down Timer / Alarm / Pre-alarm / Lap Navigation / Operation Timer
Others: System Level / Auto Display / Position Display / Direct Set / Electrim / Digital Grip Dial / Battery Alarm / LCD Contrast / 22 Model Memory-Mars-R (9 for Mars) / Model Name / Model Select / Model Copy / Memory Recall / Memory Restore / Memory Reset / Channel Select (for use of channel 3) / Beeper Pitch Shift/Adjust Volume / Set Up / EEP ROM / Output Resolution (PPM 1024STEP)
2007.12.22, 01:16 AM
Ran into this thread while searching for something else. I know this isn't the type reply that's wanted, but the Losi Micro-T transmitter works perfectly too. I bought my Z without a TX because I was on a budget and already had the T's TX. Maybe somebody can put up a post with features and a pic, or maybe this will help somebody else who just happens to wonder if they can use a Micro-T controller to save start-up costs, like I did.
| MA-010 GTR32 | Nitro Rustler | Nitro Hawk | Mini Inferno 09B | Tamiya Chevy S10 | Micro-T |
2007.12.22, 08:59 AM
No that's great info!
Kris
2008.01.30, 09:41 AM
Salt Lake Mini-Z
On the MX-A I think its supposed to be 12 model memory for the AM version and 5 for the FM version.
I also had a question about "Shift". A guy at Global hobby said that a Futaba transmitter works on negative shift and the Airtronics works on Positive shift. I thought that was only for 75mhz? If thats the case then why do both work with the Mini-Z?
Would an Aitronics MX-A 27mhz transmitter with a 27.195 crystal work with a Futaba 27mhz receiver (R152JE) with a 27.195 crystal?
2008.02.13, 02:38 PM
Yes, this Tx will work, but please check the steering response. I was using a Sportworks Tx from a Recoil rtr and the steering response was noticebly slower. A buddy at the track let me borrow his M8 and it was like driving a totally different car(in a good way). The stock KT-5 works good too. Not all TX's are created equal and just because it works, doesn't mean it works good. Just something to keep in mind.
2008.02.13, 03:57 PM
Features
Since we're talking about mini-z transmitters:
27 MHz AM module is required for this radio to be compatible with mini-z
2008.06.16, 08:41 PM
xr2i
Make sure when you buy a xr2i you buy the 27mhz band and not the 75mhz alot of the people selling them donot list this on the info so make sure you ask if not listed because the 75mhz version is more likely to be around more often than the 27mhz version . it stinks i have the 75 version and need the 27 version although i bought it for a mini t back in the day and 75mhz was way better than 27mhz more channels but now that i have a z i wish i had bought the 27mhz version
Team Dragon Racing
