Old 2016.01.15, 05:57 PM   #1
refsiul22
refsiul22's Avatar
Lightbulb Mini-Z RPM app
Just wanted to share this info with you guys. Haven't read about it in here.
Very interesting and useful. Just download the app and measure your motors rpm.
Accuracy? I don't know yet. Please comment..
Old 2016.01.15, 08:37 PM   #2
Jshwaa
Jshwaa's Avatar
Processes audio frequency to determine speed. Neat.
Accurate? Don't see why not.
Electrical Engineer
Mini-Z/RC Enthusiast
Old 2016.01.25, 07:56 PM   #3
KWT
I tried it and it wasn't that accurate.
Old 2016.01.25, 08:47 PM   #4
byebye
byebye's Avatar
Need to use a photo tachometer. I have one but have yet to really use it.
Kris
Old 2016.01.31, 11:04 AM   #5
Jshwaa
Jshwaa's Avatar
True, photo tachometers work well because you get a definite peak and valley per rotation, however using sound should work just as good as long as there is no other audible noise being picked up by the device while the motor is running, and the audio is properly filtered to give the CPU a clean signal. Using sound to calculate speed could result in a harmonic which would create a multiplying effect to the speed calculation because the sound of the motor is creating multiple peaks and valleys per rotation. But the calculated speed should be a multiple of the actual speed, in which case the device should be able to be adjusted or calibrated to mitigate that error. Other than that, using audio should work good because the frequency of sound the motor creates is a function of how fast it is rotating. Definite linear relationship. The only other possible limiting factor is how long the device takes to calculate, but we're talking about computers running on GHz speeds. Just don't social media grandma while taching your motor.
Electrical Engineer
Old 2016.01.31, 07:24 PM   #6
Jshwaa
Jshwaa's Avatar
Aw, you're no fun, Mike...
Electrical Engineer
Old 2016.02.01, 12:06 PM   #7
doug01n
doug01n's Avatar
I don't think sound is a way to check RPM. Not without external calibration with a tachometer. Changing the balance or any changes in bushing or bearings may affect the sound frequency on rotation top speed. I never saw something working (enough accurately) on this way.
Old 2016.02.01, 12:40 PM   #8
ilove599xx
I use the cheapest smart phone like Acer,
It's hard to believe that my phone could be accruated for that kind of measurement.
Old 2016.02.02, 06:44 PM   #9
Jshwaa
Jshwaa's Avatar
I suggest you spend the $3 and surprise yourself. Look up "FFT Plot - Real Time Sound Frequency Analyzer". This app works on the same principle, and people use variants to tune instruments.
Electrical Engineer
