Old 2004.11.10, 10:29 PM   #1
Skurge
servo shot
went to tke the mini-z for a spin and when i turned it on to use it all the servo grears are stripped? now what would be better to do
get a new servo.....
or
just buy alloy servo gears?
i found the servo set on tower for $84
MR-01 Mini Cooper: Topcad ball diff, Alloy wheels, 9T delrin
AE86 Corolla GT-S Micro RS4--Fast
XMODS-2x RSX, skyline, supra, civic
Skurge is offline   Reply With Quote
Old 2004.11.11, 12:47 AM   #2
davisdavis
ALL he servo gears are striped?? how can it be?
are u running a mr01? if yes, then getting new servo gears is a good idea
for $84 u can get a new miniZ RTR....
davisdavis is offline   Reply With Quote
Old 2004.11.11, 01:51 AM   #3
hehehe... i guess davis is right...
Old 2004.11.11, 05:11 AM   #4
byebye
byebye's Avatar
Too expensive for alloy. Check e b ay for better prices. Better off getting Delrin servo gears. Much cheaper. Also for close to that price you could get an mr-02 chassis set with the servo saver built in.
Old 2004.11.11, 05:40 AM   #5
HammerZ
Master of Thrash
HammerZ's Avatar
Those Cooper bodies, as I was told is rough on those servo gears.
You mention tower, so all I can say is type in [Kyosho Servo Gear] in the search box to find the stock white gears or the black delrin gears in a set. I also was told the delrin gears are a bit tight in the MR01 servo, so if you go that route check that they don't bind up.
Old 2004.11.11, 09:04 AM   #6
davisdavis
get the derlin servo gears to temporarily solve the problem~~
and i guess u have some money to spend ($84 at least, haha~ )
so then wait for the mr015 and get a RTR or just the chasis and everything needed to convert your 01 ro 015.
Old 2004.11.11, 09:15 AM   #7
Skurge
hmm ya I have an MR-01
so dont go with alloy? I figured that those would hold up for a long time(about $27 for all 3)
Old 2004.11.11, 05:12 PM   #8
Shaun
000-00-0001
Shaun's Avatar
I've been using alloy gears for about 2 years in my MR-01 Z.
Work great!
I have seen alloys break but only once.
Shaun is offline   Reply With Quote
Old 2004.11.11, 11:10 PM   #9
didn't see your signature.... stay away from the mini-cooper body... it will eat servo gears like candy... and burn a hole in your pocket spending for them as well...
Old 2004.11.11, 11:30 PM   #10
solartech
r/c user
solartech's Avatar
Hey if you really like that body,, try an aluminum bumper from CP minniraceway.
solartech is offline   Reply With Quote
Old 2004.11.12, 02:40 PM   #11
Skurge
really the cooper body is that bad? eh thats what it came with so i'm stuck with it for now
I saw they had the initialD GT-s bodies on sale......how would you reccomend those, and would I be able to just put that body on my car? I'd like to have matching cars!
basically I need a new body anyway....I cracked the cooper pretty good when the servo gears went
Old 2004.11.12, 02:55 PM   #12
ruknd@aol.com
fast and out of control
ruknd@aol.com's Avatar
Send a message via AIM to ruknd@aol.com
Skurge...I'm liking the I waver bodies they are not nearly as detailed as the kyosho and the plastic jsut feel cheaper but they are cheap...got two bodies and kyosho med wide wheels off the bay for 10.50.
ruknd@aol.com is offline   Reply With Quote
Old 2004.11.12, 03:10 PM   #13
Skurge
ya know I didn't think of looking for the iwaiver bodies on ebay.......i'll have to look into it
Old 2004.11.20, 12:59 PM   #14
stuZ
mini-z muckraker
stuZ's Avatar
I had an all alloy servo gear setup in one of my 01's, and it began to bind, so I mixed in some delrin gears between two 01's, and they both work way better. I'd suggest delrin, it's about as strong as aluminum, and only about 6-11 bucks for a kyosho set.
stuZ is offline   Reply With Quote
Old 2004.11.20, 08:30 PM   #15
Skurge
well I ended up ordering the delrin gears......just waiting for them to come
Portugal OL joel Mini-Z Overland MV-01 11 2007.08.24 01:06 PM
how to clean servo gears??? doongas Beginner Questions 3 2006.04.06 12:01 PM
mini-z hybrid with micro electronics bdreeft Mini-Z Science 8 2003.06.18 04:06 PM
servo convertion killer Mini-Z Science 21 2003.01.03 07:30 PM
Help a noob with servo twitch! ianc Setups 4 2002.06.08 05:31 PM
