Old 2010.12.29, 02:10 PM   #1
briankstan
SLMZ / HFAY
briankstan's Avatar
compatible with windows 7
I'm looking to upgrade my laptop here soon, upgrade meaning getting a new one.
Anyone running Flipside timing software on Windows 7? any know issues?
Old 2010.12.29, 03:45 PM   #2
i keep an updated copy of flipside installed on my laptop which is now running win7 home premium 32bit. i actually have not run any timer with this as i typically use my ancient backup xp pro laptop however i can give it a try this weekend unless someone else has already tested win7.
Old 2010.12.29, 05:26 PM   #3
I-Lap
We are running Flipside just fine on both 32 and 64 bit versions of Windows7.
This is with I-Lap hardware, you should verify your hardware is compatible and make sure a driver is available.
We also use his ICS software on both as well.
Craig
I-Lap Timing Systems
Precision Timing for Small Scale Motorsports
www.rclapcounter.com
I-Lap is offline   Reply With Quote
Old 2010.12.29, 05:28 PM   #4
briankstan
SLMZ / HFAY
briankstan's Avatar
Ray, can you test this with the core hardware?
Craig
thanks for the info.
Old 2010.12.29, 08:22 PM   #5
pinwc4
pinwc4's Avatar
Windows 7, 32 and 64 bit, should be fine as I-Lap mentioned. While I do not have it yet I made sure to update the software a long time ago to be compatible. I do not have an actual 64 bit version (it would provide no benefit) but the 32 bit copy will work fine on 64 bit Windows.
For the core hardware you will need to make sure to install the driver. Download the driver before you plug in the hardware for the first time. When you first plug in the core hardware it will probably ask you for the driver, you can point it to the location you downloaded it to. The download link can be found here:
http://www.ftdichip.com/Drivers/VCP.htm
Old 2010.12.29, 08:27 PM   #6
briankstan
SLMZ / HFAY
briankstan's Avatar
Thanks for the info.
Old 2010.12.29, 09:18 PM   #7
BrianMidnight
Installed Windows 7 32 bit build 7100 in May 2009. Been using Flipside software/Core hardware with it ever since........no problems.
BrianMidnight is offline   Reply With Quote
Compatible AM Radios ChiMiniRc Transmitters, Receivers and Crystals 6 2010.07.03 06:27 PM
FS: USB ICS cables for Mini-Z/dNaNo; Mac, Linux and Windows compatible pinwc4 Mini-Z Marketplace 1 2010.06.13 10:40 AM
FS FT: MA010 - MR01 - MR01.5 Compatible Narrow Bodies & Monster Body Draconious Miscellaneous Discussion 23 2006.09.28 04:12 PM
clear plastic for windows PatTink Custom Bodies 11 2004.03.29 01:35 PM
compatible parts marc12 Mini-Z Monster MM-01 0 2004.01.10 08:57 PM
