Old 2018.11.04, 06:13 PM   #1
MPG1959
RCP track, Smooth side up rough side up?
New to mini z's. I just picked up a RCP track and cars used, what side up do you run? and what tires?
MPG1959 is offline   Reply With Quote
Old 2018.11.04, 06:43 PM   #2
Qball41
Lots of variety on tires. I'm usually around 15 degrees rear, 20 degrees front.
In the track, we just formed a new group and we are racing on the smooth side.
Qball41 is offline   Reply With Quote
Old 2018.11.04, 07:11 PM   #3
Welcome... I actually haven't tried the smooth side yet... but for the rough side kyosho 30 front 20 rear.. if you find yourself traction rolling go for 40 fronts.. tire choice is about 80-90% of your set up... so choose wisely.. hope this helps...
Old 2018.11.04, 07:20 PM   #4
Smooth side is the way to go especially if you want reduced tire wear. But on either side be sure to stay away with any silicone based tires as they will destroy the racing surface. Once it gets into the surface it is virtually impossible to get it out.
Old 2018.11.04, 07:59 PM   #5
MPG1959
So you say stay away from silicone tires, what brands to Run?
Old 2018.11.04, 08:00 PM   #6
MPG1959
Thanks for the input guys
Old 2018.11.04, 08:46 PM   #7
I think PN is probably the most popular brand. They have two RCP formulations, in slick and treaded.
I usually use PN Racing Mini-Z KS-M Compound RCP Radial Rear Tire SOFT and PN Racing Mini-Z KS-M Compound RCP Slick Front Tire SUPER SOFT, but sometimes go with SOFT or MEDIUM up front, and sometimes SUPER SOFT in the rear.
I'm interested in trying the Marka tires next time they are in stock. I also use Kyosho tires, and their rating system is a little different. The Kyosho tires last longer than PN, and have a longer shelf life, IMO.
Old 2018.11.04, 09:11 PM   #8
MPG1959
Cool thanks
Old 2018.11.04, 07:22 PM   #9
I race on rough and smooth at different venues. Kyosho 20 rear and 30 fronts works on both. Smooth side has a little more initial and overall mode more traction than the rough side. I raced on the rough floor many more years before trying the smooth, and prefer the smooth side since there is more consistency.
HFAY - RCP track side? smooth or textured? briankstan How Fast Are You? Online Points Series 15 2016.05.20 03:19 PM
New RCP Track Tiles/Rails/Discs for the Mini-96, dNaNo, Mini-z and HPI 1/32 RCPMini-z Tracks and GTGs 33 2010.10.13 09:11 PM
Different coded / keyed Kyosho RCP and normal RCP? Ensonic RCP Tracks 10 2010.02.19 12:02 PM
RCP REleases New Super RC Speedway into the Toy Industry RCPMini-z RCP Tracks 10 2009.09.30 04:24 PM
RCP Tile Cut Pattern Variant RCPMini-z RCP Support Forum 0 2007.07.23 08:35 PM
