2010.04.23, 03:12 PM
#31
i looked around but did not see an answer to weight limits for this event. id like to have my cars setup soon so i can tune with the added weight.
2010.04.24, 05:19 AM
#32
Ain'tSoldEm
We will do a Junior, or beginner's, class as long as we get at least 4 . It will be a seperate class that will allow cars that fit in our Stock or LM class rules. The class does not require a handout motor and the entry fee will be $5.00 for this class only. You may elect to run a handout motor for another $5.00. All 70T motor rules apply to the non-handout motors but this shouldn't be a problem with the level of experience of the driver's, slower is better for new guys (even for old guys too sometimes).
Let me check on the weight rules... our weight rules are set with the AMB transponders and we will be running Core, which is considerably lighter. We may need to adjust.
High Speed Hobbies
2010.04.24, 06:13 AM
#33
Ain'tSoldEm
Here are our current rules in effect for our normal Thursday night races and the HS Carolina's Cup events. Let me check on weight reductions due to the transponder weight differences. The rules have been amended to specifically allow Mantis' F1 parts.
HIGH SPEED HOBBIES
1/28TH SCALE RACING TECHNICAL RULES
RELEASED MARCH 16, 2010, AMENDED APRIL 24, 2010
Stock
Chassis and Body
Kyosho 01, 015, 02 and 03 base chassis only.
Colored Kyosho option chassis allowed.
NO aftermarket chassis allowed, i.e.: Inzane P-28, MRCG, etc…
All Kyosho option and aftermarket suspension and drive train parts allowed.
Wheelbases allowed: 86mm – 100 mm.
Kyosho, IWaver or TRP street car based bodies only.
NOT allowed: Le Mans Prototype (Porsche 962, Mazda 787, etc…), PN Pan, Atomic VDS or Lexan (polycarbonate) bodies.
Motor – Board
Equivalency formula, these combinations are allowed:
SINGLE LAYER FET combination on AM board only, any FET allowed (1 pair 3004, 3010, 4562, 8858 etc…). External turbo boards not allowed.
ONLY the following motors may be used:
PN 70T, PN Speedy07 Bush and BB, PN Speedy05, Kyosho stock motor or X-Speed. No armature swapping between motor types or rewinding, unwinding allowed. Magnets as supplied by manufacturer for motor type, no swapping or substitutions.
OPEN BOARD, any number, type and combination of FETs allowed. External turbo boards are allowed.
Only 2009 version of PNWC 70 Turn Official Stock Motor (PN Part #110670) allowed.
The PN 70T can may not be opened; the end bell may not be removed. All internal parts must remain stock.
Only the PN Carbon Silver brush (PN Part#10CR50) or Atomic Carbon brush (Atomic Part#AR008) may be used. The brush spring must snap into the end bell receivers in the original location and orientation. No material may be added or removed from the brush spring.
(Handout motors may be required at special events)
NOTE: Boards and motors can be checked at random by HSH staff or designee.
Weight
Minimum of 175g (CC Events) with batteries and transponder.
Tires and Wheels
Rubber tires only.
Any plastic or aluminum wheels allowed with the following dimensions:
Maximum front width: 8.5 mm.
Maximum rear width: 11mm.
Maximum diameter: 21 mm front and rear.
Le Mans
Chassis and Body
Kyosho 01, 015, 02 and 03 base chassis only. Colored Kyosho option chassis allowed. NO aftermarket chassis allowed, i.e.: Inzane P-28, MRCG, etc…
All Kyosho option and aftermarket motor pod, suspension and drive train parts allowed.
Wheelbase allowed: 102mm.
Kyosho Le Mans Protoype bodies only (Porsche 962, Mazda 787, etc…). PN Pan, Atomic VDS or Lexan (polycarbonate) bodies not allowed.
Motor – Board
NOTE: Motors can be checked at random by HSH staff or designee.
Weight
Minimum of 185g (CC Events) with batteries and transponder.
Tires and Wheels
Kyosho Le Mans tires only, all available compounds.
Any plastic or aluminum wheels allowed which fit the Kyosho Le Mans tires. Front specific tires must be run on the front and rear specific on the rear.
Formula 1
Chassis and Body
Only Kyosho plastic F1 chassis allowed.
Only Kyosho F1 bodies allowed. Aftermarket wings and bumpers allowed.
Motor – Board
Any brushed 130 sized motor is allowed. Brushless motors not allowed.
Weight
Minimum of 200g with batteries and transponder.
Tires and Wheels
Kyosho Formula 1 or equivalent aftermarket tires only, all available compounds.
Only plastic or aluminum F1 type wheels allowed
High Speed Hobbies
2010.04.24, 06:19 AM
#34
Ain'tSoldEm
If we could get everyone interested in attending, that reads the forum, to post up, we would like to get an idea of handout motors needed. If you know of someone attending that does not read the forum please let us know. I will ask Wade to start a driver's list on his first post as an edit.
I will be running Stock, LM and F1.
High Speed Hobbies
2010.04.24, 08:02 AM
#35
i will be running all as well
2010.04.24, 09:21 AM
#36
Give me what classes you'll be running.
Wade
2010.04.24, 02:33 PM
#37
I will be running Stock, LM & F-1.
Andy
LET'sGo Racing
2010.04.24, 03:40 PM
#38
Village Idiot
All 3 baby, yeahhhhhhhhhhh !!
James
MWG Racing
2010.04.24, 07:30 PM
#39
well i think i'm running all three?i was told i might have a F-1 sponsor . collin might be running stock and LM,and griffin is gonna run the newbie class . do you offer a multi car discount .
2010.04.24, 08:31 PM
#40
The Mad Mexican
I will be running all three classes as well!!!!! Is there a discount for minorities?
Jay Vasquez
MWG Racing
2010.04.25, 06:21 AM
#41
of both Time and Space
How about a discount for the follicularly challenged?
I will run all 3!
2010.04.25, 07:50 AM
#42
Nothing grows at that altitude. Nothing. Not grass, trees or foliage of any kind. We are all a little jealous that you have a built in driver's stand. Jay probably more so than the rest of us
2010.04.25, 08:29 AM
#43
Mike, I took the liberty of entering you In all three classes. Are you going to attempt F1?
Wade
2010.04.25, 09:15 AM
#44
You know Im in for all three!!
Landon
LET's Go Racing!
2010.04.25, 09:18 AM
#45
Wade
In for a penny in for a pound.
