Old 2006.04.09, 06:01 PM   #1
Roketmini
The C is Missing.
Roketmini's Avatar
Send a message via AIM to Roketmini
Xmod Bearings?
Can I use Gen 1 Xmod Bearings in my OL instead of the bushings? They look like they'd fit.
Support your LHS
Roketmini is offline   Reply With Quote
Old 2006.04.09, 06:22 PM   #2
You can only use them on the rear end where the axle goes through the motormount, and the outside of the rear wheel closest to the differential spur (the other wheel is locked to the shaft, so bearings on that side would be useless).
The front wheels use a smaller inside diameter (2mm while the Xmod ID is 3mm), so they would be useless.
bearings all the same? marc Mini-Z Science 17 2008.09.30 04:00 PM
bearings bearings and more bearings builthatch Parts and Hop-ups 3 2006.12.13 01:59 AM
XMOD Evo F-150 For SALE! Sky Miscellaneous Discussion 0 2006.11.15 09:14 PM
Xmod Turning TNB Mini RC 8 2004.06.10 12:32 PM
Xmod Bearings compatible for MMT Dracer07 Mini-Z Monster MM-01 0 2004.06.09 02:46 PM
