2005.06.26, 03:47 PM
RCP track ideas
I posted some pics of my latest home rcp track layout. It might give some ideas for people that have a support pole in the way of making your track bigger. I cut the track out, so the pole is in middle of streight. I padded the pole. I took out the wall, added thin strpes of track to fill in and made foam plugs to fill in where the holes from track wall pins were. That gained me a couple more inches at pole. As you can see i used the long front streach as the wall for both streights. I also rounded the 1 corner off.
2005.06.26, 03:49 PM
Heres the rest of track pics.
2005.06.26, 04:00 PM
Warbirds & Monster Trucks
Great idea and nicely executed!
2005.06.26, 04:01 PM
better put some scale water/sand tubs, made of foam infront of that pole... thats gona hurt lol.
2005.06.26, 04:17 PM
fast and out of control
or collect your old worn out tires for stacks, heh.
2005.06.26, 08:12 PM
The foam i put around is the track walls cut in half. I put yellow tape around to see it better. Plenty of protection for cars and doesnt take to much room up.
2005.06.26, 08:53 PM
I agree, very nicely executed.
That pole is pretty scary, but at least it's right after a turn, so speeds wouldn't be too high at that point.
2005.06.26, 10:25 PM
BooYa!!
That pole spices it up a bit . Where i run 1:10 we have a light pole to deal with, and it's solid concrete and the guy the runs it doesn't pad it . However since he lets us do the track leyout we useally try to put a board there.
2005.06.27, 06:47 PM
The guys are handling the pole pretty good. Better than i thought.
2005.06.27, 06:53 PM
ready to race...
big scary pole.....gives me nightmare daydreams of my past track...(2x4's as walls)
2005.06.27, 06:56 PM
The more you run it, it seems like its not there..............almost!
2005.06.29, 02:33 PM
BooYa!!
You could always add some more obstacles/traps and stuff to make it more interesting.
2005.06.29, 04:01 PM
traps and obstacles? whats next a put put windmill?
2005.06.29, 07:37 PM
I save the traps and obstacles for the overlands.
2005.06.30, 03:45 PM
BooYa!!
