Old 2008.01.25, 02:46 PM   #1
RacingSOUL
RacingSOUL's Avatar
Send a message via ICQ to RacingSOUL Send a message via MSN to RacingSOUL
Smile MR-02mm Race Setup question
Hello All! Can You help me to make best setup for my car, please?
I want to get into mini-z's competition in my city.
Currently there are 3 classes in "racer":
1) stock (from the box);
2) hobby;
3) modified/unlimited.
I want to participate in hobby class. The main rules are:
- stock kyosho motor (without modifing);
- ni-mh, ni-ca accus;
- only kyosho mini-z bodies;
- diff 44t, pinion 6,7,8,9t;
- rewiring allowed;
- os-8 family fets, 1 per channel allowed;
- allowed aluminium parts that doesn't influence on car's performance (i.e. kyosho's aluminium motor pod), 0 degrees front parts (knuckles, toe etc.);
- allowed carbon H-plate;
- minimum weight - 185 gramms (with accus and everything else).
I decided to follow these main ideas:
- less weight;
- less wires and other power-eating things.
So... the body, that I've chosen, is silver McLaren HD kit due to its durability, stability and minimum weight. Chassis - MR-02mm.
Changed:
- removed rear wing, headlight's glasses;
- tires: 20 rear normal form), 30 front (normal form) + glued them on wheels;
- wheels - 0 offset rear/front;
- delrin kyosho diff;
- delrin pinion (9t installed);
- aluminium wheel nuts;
- longer antenna - 180mm;
- carbon H-plate (medium);
- bought new Kyosho's stock motor (it's better than motor from box) and removed resistor (it is allowed);
- changed fets to IRF7317, 1 per channel (4562 aren't available here, so the 7317's are the closest to them);
- rewired motor;
- removed dinky on/off switcher (less power loss);
- greased everything that should be greased =);
- polished diff shaft and kingpins;
- experimenting with accus: varta, sanyo and duramax (lenmar is also available, but haven't tested it yet).
The time is 2-3 secs better, than stock car. The only thing is car sometimes flips while turning 180 degrees corners... Maybe wider base? (+... offset rear/front wheels?)
What do You think else could be upgraded in this case?
Thanks in advance!!
Mini-Zs:
- MR-02mm - McLaren HD kit/Lamborghini Murcielago/Ferrari Enzo (1x2 7317)
- MR-02rm - Lexus SC430 2006 test car (2x2 7317), "Hello Kitty" Lexus SC430 (2x2 7317, Reflex Racing Modified MR-02 Team Replica '08), Ferrari F360 GTC (2x2 7317), Ferrari 575 Maranello (2x2 7317)
- MA-010 - Nissan Skyline GTR R34 Nur (2x2 7317)
RacingSOUL is offline   Reply With Quote
Old 2008.01.25, 04:27 PM   #2
minittrackmann
minittrackmann's Avatar
Thats about all you can really do. I dont no what you said about what Transsmitter you are using. Your car is modded to the extreme for stock class!! LOL
Cody
minittrackmann is offline   Reply With Quote
Old 2008.01.25, 04:46 PM   #3
kja812
EE
Harder front springs may reduce your body roll on a hard corner and prevent the flips.
kja812 is offline   Reply With Quote
Old 2008.01.25, 04:57 PM   #4
So you're not allowed to run negative camber? Shame, normally camber helps a lot with flips...
Can you lower your body/chassis without rubbing or bottoming out? Lower CG obviously helps with flipping, but only if it doesn't cause other weird issues.
Old 2008.01.25, 06:14 PM   #5
RacingSOUL
RacingSOUL's Avatar
No, AD band boards aren't allowed... Optional transmitter is allowed, but I think futaba 3pk is too much for a stock class. And only kyosho's stock springs.
Thinking of getting aluminium knuckles 0degs and +2 offset rear wheels (where is my dremel?), will experiment...
And another upgrade could be soldering antenna to wire and soldering motor wires to board + soldering power board wires to battery clips...
Uh uh uh
Thank You all for replies!
Mini-Zs:
Old 2008.01.28, 12:54 PM   #6
Tjay
Tjay's Avatar
coming on the turn, slow down (let the the throttle finger off easily) take the turn smoothly (don't yank the steering). Most of the people would just work on their cars because the car is doing this and doing that. Think of the car as if you were inside the car and driving it...
In our track we have few 180 deg. turn. I have a McLaren and SC430 in mod class. Let me know if you want my set-up. I will help you to it.
good luck!
Race Event - Saturday - 02/09/08 - ALTERNATE LOCATION! AtlRC Atlanta Mini Scale Racing 17 2008.02.16 08:19 AM
MR-01 Motor Setup Question xrayrc Mini-Z Racer MR-02 3 2008.01.19 02:06 AM
MR-02 RM Race Setup enzo1978 Mini-Z Racer MR-02 14 2008.01.03 08:21 AM
Ultimate Road race setup ? karlos Setups 11 2002.09.09 11:14 AM
F-1 setup question gargoyle7642 Mini-Z F1 MF-010, MF-015 1 2002.08.25 08:47 PM
