Old 2007.02.19, 09:37 AM   #1
Mr-02
A new generation Mini-Z chassis shows new running style and scale form.
As the world of micro racing has spread around the globe, the MR-02 chassis promises even more scale variety. With its concentrated mass and ultralow chassis height, the low center of gravity and intense compact nature of the MR-02 give it the Mini-Zs highest performance specifications. Even more running performance potential has been added, and the components combine easily to produce an even higher-level result. Add the MM-type and LM-type mid-ship motor mounts to the RM-type rear motor mount for a three-version line-up. In response to various wheelbase and overhang differences, a wide range of body styles can be developed to accelerate the level of fun and appreciation in building your own collection. With even more Mini-Z sophistication than the original Mini-Z, the MR-02 chassis can show the real enjoyment of micro motor sports like no other.
Chassis Technical Data
Length 125~133mm
Width 68~76mm
Ground Clearance 4mm
Wheelbase 86~102mm
Tread (F/R) 59~65mm
Tire Size (F/R) 258.5~11mm
Gear Ratio 7.3, 6.3, 5.5, 4.9 : 1
Weight (approx.) 130g
Battery(notincl.) AAA-Size x 4
Motor(incl.) 130 Type
Features
Simplicity makes maintenance easy. Uses kingpin coil-type front suspension. Optimum structural geometry realizes mild control characteristics. Due to the snap-lock system, the kingpin, coil spring and tie-rod can be installed or taken out by simply removing a C-ring. This makes maintenance and tuning easy.
Compact chassis is packed full of sophisticated components. High frequency FET speed control amp with reverse and brake function, rear damper, servo saver, and gear guard are all included as standard features. Lower CG and lower chassis height with concentrated mass in the center all result from the parallel layout of the battery mounts. The chassis bottom layout produces greatly improved racing performance.
The swing-type T-bar rear suspension produces excellent road holding. On various indoor surfaces, free traction control and tail control are possible.
Chassis Configurations
MM chassis/ Mid-ship Motor Mount: On the MM chassis, the motor is mounted mid-ships directly in front of the rear axle. Mass is concentrated in the center and produces good agility and a shorter rear overhang.
RM chassis/ Rear Motor Mount: On the RM chassis, the motor is mounted behind the rear axle. Positioning the C of G at the rear produces high levels of traction. This makes tail control all the more interesting. RML chassis omits the top damper to generate lower chassis height for the RM chassis.
LM chassis/ Mid-shop Low Motor Mount: Latest chassis design is the fastest MINI-Z Racer ever. With the motor mounted 5.5mm lower on the 3L size long wheelbase chassis (compared to the MM motor case), the motor can be positioned much closer to the lateral center. The stability of the chassis has dramatically improved with small diameter wheels, newly designed front knuckles, a 1mm lower chassis and a friction damper now standard.
Electronics Configurations
Standard AM radio system combines the receiver and speed control for efficient running and precise control. New RA-4B FETs allow better power handling.
(No picture) i-Series: Receiver with efficient FET speed controller allows precise run times. The removal of reverse feature makes the i-Series even more competitive on price.
(No picture) AD Band: Special FM radio system provides excellent signal stability and digital servo control. The unit is fitted with I.C.S. that uses graphical representation for precision servo and motor control amp settings through a computer. AD Band MR-02 (RA-6 I.C.S) receives special yellow plastic on the chassis.
The latest ASF 2.4GHz unit delivers the amazing experience of micro motor racing. Fastest signal processing speed available produces a truly direct control feel. FET with double the capacity of previous models also features LED that indicates power status when power is switched ON. The ASF 2.4GHz unit is also fitted with I.C.S. that allows servo and motor control settings through a computer.
MR-02 STOCK PARTS KITS
No.MZ201 MAIN CHASSIS SET MR-02
No.MZ201B MAIN CHASSIS SET MR-02 (Revised)
No.MZ202 SMALL PARTS FOR CHASSIS MR-02
No.MZ203 FRONT SUSPENSION PARTS SET MR-02
No.MZ203B FRONT SUSPENSION PARTS SET MR-02 (Revised)
No.MZ204 MOTOR CASE SET MM
No.MZ205 SERVO SAVER ASSEMBLY MR-02
No.MZ206 REAR SHOCK SET
No.MZ206B REAR SHOCK SET (Revised)
No.MZ207 REAR DIFFERENTIAL GEAR ASSEMBLY
No.MZ208 SCREW SET MR-02
No.MZ209 R/C UNIT SET MR-02
No.MZ6BK PINION GEAR SET BLACK
No.MZ8-1 SERVO GEAR SET
No.MZ8-3 SERVO GEAR SHAFT SET
No.MZ9 MOTOR SET
No.MZ9P MOTOR SET (Revised)
No.MZ10 ANTENNA SET
Special Editions
Tenth Anniversary MINI-Z Cup Edition
This special MINI-Z Cup Edition model prepares you for a winning start with a chassis that is built to win from your first R/C racing experience at the MINI-Z Cup. Equipped with a range of optional parts as standard, this special edition delivers greater efficiency, setting options and durability with parts that many drivers choose for their winning edge. To mark the special significance of this anniversary model, the special aluminum parts are also anodized in red (not available for sale). As there is no receiver and amp unit included, you can add your preferred (or existing) control system to deliver this model's unique performance but with the control characteristics of your own unit. With only 1000 in existence, this unique model puts the magic of the MINI-Z in your hands.
MINI-Z Cup Edition Special Features
No.MZW1 Ball bearing
No.MZW13R Color nylon nuts
No.MZW203 Stainless steel king pin
No.MZW205 Carbon rear suspension plate MM (soft only)
No.MZW206 Ball diff. set (special red anodized finish / not available separately)
No.MZW207 Pitching Oil Shock (Rear)
No.MZW220 Friction Shock Set MM (special red anodized finish / not available separately)
No.MZW301 Xspeed MINI-Z motor V (for ASF)
No.MZW37-30 Racing radial tires 30 degree (for front)
No.MZW38-20 Racing radial wide tires 20 degree (for rear)
Special gold hairline name plate
Images and text are property of Kyosho Corporation, and used on this page only for informational purposes.
arch2b is offline
Closed Thread
