Go Back   Mini-ZRacer.com Forums > General Discussion > Beginner Questions
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 2006.04.06, 10:35 AM   #16
Originally Posted by byebye
EMU if there are any more changes just post the new file here and I'll replace it for ya.
-Byebye
Thanks, I will do that... I am going to work on it now.
edit: I have attached a revised version. If anyone has the offsets for the Lamborghini LP400, that would be appreciated.
Old 2006.09.07, 06:48 AM   #17
HammerZ
Master of Thrash
HammerZ's Avatar
LP400 offsets; front N 1.5mm, rear W 0. The wheels are listed as classic profile.
Information off the setup sheet. Hope this helps.
Old 2006.09.07, 10:09 AM   #18
Thanks Hammer When I get a chance, I am going to update the chart with the new information...
Old 2006.09.07, 12:52 PM   #19
LouC
EMU- nice to see you back on the board!
Look forward to seeing your updated chart.
LouC is offline   Reply With Quote
Old 2006.10.23, 03:43 AM   #20
byebye
byebye's Avatar
Just wanted to give this thread a bump. I've moved it to beginner questions but it will eventually get move to the FAQ.
-Byebye
Old 2006.10.24, 01:50 PM   #21
stuZ
mini-z muckraker
stuZ's Avatar
is the third one over listed as MR010 really the awd(MA-010) or mr01?
(I'm assuming it's for the awd)
stuZ is offline   Reply With Quote
Old 2006.10.24, 11:22 PM   #22
MR-010 uses the same offsets as the MR-01 and MR-015. So it will look very similar. I know that this really needs an update... and I will try to get to it as soon as I can. Ive been double shifting at work, and going to school in between...
The reason there are 3 columns is that not all MR01 or MR02 bodies can be used on the MA010, so a seperate column is needed.
Old 2006.12.21, 09:56 PM   #23
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
EMU, I don't know if this info is useful to your chart, but I fit the following autoscale bodies on an mr o2 with -1 narrow wheels in the front and -1 wide wheels in the rear.
Mini cooper
ae86 corolla or known as sprinter trueno
R34 skyline
I have sucessfully tested the mini and it works well. I don't know if anybody has already tried fitting these bodies on an mr o2 or not. But I hope this information is useful.
Old 2006.12.21, 10:46 PM   #24
Mini cooper
R34 skyline
Thanks for the info... I have already seen the Mini in action on an Mr02... I havent seen the others in action yet. I will add the data in the next revision of the chart (I need to overhaul it badly, but havent gotton the time).
Old 2006.12.22, 09:15 PM   #25
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
I just got around to putting the corolla body on my mr o2 and hopefully will get around to fully testing it this weekend. I only got to drive it around the kitchen floor at the moment. I also got the following bodies to fit on the mr o2,
Honda S2000
Dodge viper GTS-R
Toyota altezza
BMW Z8
I use -1 narrows in front and -1 rear wides in the rear with these bodies, but I believe
on the viper and S2000 bodies U can fit 0 offset wide wheels in the rear. I'm pleased with the way the corolla is driving so far but I will really know how it would handle when I get it on my track. The bodies require little to no modifying.
Old 2006.12.22, 09:49 PM   #26
Honda S2000
Dodge viper GTS-R
Toyota altezza
BMW Z8
The Z8 is a little too narrow for the MR02... even on an MR015 with 0mm wheels it barely passes... the front tires come off with a good brush on the wall... however, it is a very light body... and a blast to drive...
S2000 is a nice body on MR02, Viper is pretty decent... I am going to test fit the Cobra Daytona this weekend, and build up a chassis for the body (whether it is 015/02, I am going to get a chassis set for it tomorrow)...
Old 2006.12.22, 10:18 PM   #27
Lionblade
Honor & a shot of sake.
Lionblade's Avatar
Send a message via AIM to Lionblade Send a message via MSN to Lionblade
Magic had a S2000, didn't he? That thing was a beast. Might do something like that myself.
Lionblade is offline   Reply With Quote
Old 2006.12.23, 12:53 AM   #28
Its fun to drive smaller cars... makes it a lot more challenging though... you will lose battles with the bigger cars, so you have to drive careful.
Magics S2000 was nice... handled like it was on rails...
Old 2006.12.23, 04:10 AM   #29
Ninja
Mechanic
Ninja's Avatar
The Corvette is listed as 1.7w on the rear for the 015 but 3w for everything else. The problem with this is that all the rear axle widths are the same. The measurement should be changed to 3W.
also the Supra fits the AWD with the PCB cover removed and laydown adapter. same wheel offsets as the 015
Real Racers Do It Sideways.
Old 2006.12.23, 01:09 PM   #30
The wheels that come with the C5R are 1.7W for the rear... 3W can fit without a problem, but I felt that if you want to use the stock wheels, then you would use them on the 01/015 chassis which is why I listed it like that...
Dogbreath Body Mounts How To DogbreathRacing Mini-Z Overland MV-01 6 2004.05.09 11:54 AM
F1 mini z w/ reg body? abefrohman71 Mini-Z F1 MF-010, MF-015 1 2002.01.18 11:28 PM
mini z lite and civic body? frogg Custom Bodies 1 2002.01.12 04:39 AM
