Old 2014.02.06, 02:00 PM   #1
shaggy33
015 or 020
My lhs has 015 chassis sets and I am wondering if should buy that for drifting or should I get the 020 when it's in stock?
I think you can make the 015 to an 020, is this right? Is there any major differences between the 2?
Also I imagine more bodies fit the 015 that 020 or do they both take same bodies
Any advice appreciated
shaggy33 is offline   Reply With Quote
Old 2014.02.06, 02:42 PM   #2
gctkaz
You have this posted in the MR-015 forum.
Are you comparing the RWD MR-015 and MR-02, or the AWD MA-015 and MA-020?
If you are just drifting, any AWD chassis will be fine, just keep in mind there are IMO more nice-looking drift bodies that use a narrow front end and 90mm wheelbase, so if you get a MA-020, you should install the narrow front anyway. I believe the AWD chassis should be compatible with all bodies, not certain if DWS rear end can go down to 90mm wheelbase though.
Drift tires are a must, everything else is optional although a spool rear diff makes things much easier to control.
If you are actually keen on drifting with a RWD chassis, it is very difficult to control and there is not really enough steering angle. A MR-03 with a gyro installed may be your best bet.
gctkaz is offline   Reply With Quote
Old 2014.02.06, 03:06 PM   #3
shaggy33
Sorry! Comparing awd 015 and 020 so I will take your advice and just get an awd chassis I be it 015 or 020
Old 2014.02.07, 08:23 AM   #4
NoBrainer
NoBrainer's Avatar
with the new front on MA-020 I think that would be your best option.
But then again, there are plenty of hop-ups for MA-015 so it might not differ.
I would get the MA-020 just because of the new servo and electronics.
NoBrainer is offline   Reply With Quote
Old 2014.02.07, 09:40 AM   #5
It's the same servo internals.
I don't think the electronics are much different unless it's an upgraded VE system.
I think 020 would be a good option though...if you can drift you can drift pretty much anything so an 020 would also give you a more recent and competitive racer if you ever get into that.
my custom body album...
Old 2014.02.08, 07:24 AM   #6
NoBrainer
NoBrainer's Avatar
sorry, my bad.
Converting front track of 015 to 02 babstar Mini-Z Racer MR-015 15 2014.08.25 08:02 AM
WTB: ASF boards for 015 and 02 chassis WorldClassZ Mini-Z Marketplace 0 2011.11.19 03:12 PM
Setup help, new to the 015! babstar Mini-Z Racer MR-015 11 2009.08.13 11:04 AM
FS: MR02 w/ 015 Conversion & Mobile1 NSX bnwhtlw Mini-Z Marketplace 5 2007.05.10 07:47 PM
Any one try the PN front tower set 015 on 02 ByronF1 Mini-Z Racer MR-02 1 2007.02.28 05:06 PM
