2005.05.06, 06:24 AM
Best all around Stock Motor to use without Fet upgrade
Hello
I have searched this forum extensively for motors to run without fet upgrade. Although there is vast information, I haven't found many threads comparing the various motors. My objective is to concentrate all that information in one thread. Here is the list I came up:
Kyosho Xspeed
- 50T
Has been said to be the safest motor upgrade
Originally Posted by superpeltor
x-speed has speed increase on all area, slow or fast
Iwaver Xspeed Plus
- 27T
- Large commutator
- Strong magnets
Much controversy about the ability to run this motor with stock fets
Originally Posted by Fidalgo
Iwaver 02 board doesn't stand for iwaver Xspeed or Xspeed pro motors. Only iwaver 01 pro board.
Originally Posted by Hammer0412
I've been using an Iwaiver Xspeed on my stock Iwaiver 02 with a 7 tooth pinion with no problems. I've read some posts of knowledgeable people here in this forum saying this was ok so I went ahead and installed this set up.
PN Speedy
- 52T
Considered one of the fastest
Speedy BB does have more torque at bottom end of power curve. When I race, a lot of times, I limit my throttle to 70%, sometimes less so I can race with stock motor guys. Speedy BB has more torque at reduced throttle setting. Speedy BB has stronger magnets and it helps out on torque more than x-speed motor. When you back off throttle, those magnets slows car down very quickly. (a lot of engine braking) but x-speed tends to coast a little longer(or smoother).
ATOMIC Stock
- Dual ball bearing
- High torque
- High Grade Brush
Originally Posted by Roger
There was this guy at our track and his x-speed was ballistically fast. His car was bone stock with no fets. I looked at his car, and sure enough, a stock esc with no mods. He's a good driver also, but we tested his car against another mr-02 that had a atomic stock motor with the same gear ratio, and his x-speed ate the atomic motor for dinner . Both drivers were equally matched in skill, but when that x-speed came out of the corners, it had so much torque coming out.
[M'z] Hand Wound Stock Motor
- Bearing case
- Black magnet
http://www.chaserrc.com/product.php?op=view&proid=3
MiniZWorkshop Blue Power
- 45T
Originally Posted by ollymalone
If U want the FASTEST possible get the 45 turn from mini-z worksop. it dosent need fet or turbo and it rips on the x-speed and pn racing BB. so get thet and its olny 14 bucks or the can get the blue speed same turns but i dont think it has as much high tech stuff its only 11 bucks. But u need good tires.
Also, how does the none ball bearing motors listed here compare with the others when inserted in a BB can?
And how these motors would behave with Neo Magnets? Would the fets hold on?
I am not looking for the fastest motor, I want the one that has the best ratio of top speed, torque and control.
Your thoughts and ideas will be appreciated
2005.05.06, 11:32 PM
i have 5 miniZ's all use kyosho Xspeed with bb case~
so far the best non-fet motor i've tried.
and the bb case i use are either Atomic/Audley, but need to be careful and a little skills when installing BB case, orelse the motoro will run slower than the origianl Xspeed
i have a 6th motor lying around...also a kyosho Xspeed without modification.
so many Xspeeds~~ haha
2005.05.07, 05:56 AM
Could you tell me wich others have you tried?
"The most beautiful things in the world are those from which all excess weight has been removed" -- Henry Ford
2005.05.07, 09:09 AM
Mechanic
i have run the 3-Racing BB motor alot, i think it is about 3-5kph faster than an x-Speed with same gearing, it is pre-drilled so you can use it with PN mounts, and it has loads of torque
Real Racers Do It Sideways.
2005.05.08, 12:53 AM
I just purchased a PN Speedy motor from the bay. The main reason I bought it was for the pre-drilled holes. So far I've had the most success with the Kyosho X-Speed motor. The fastest I've used thus far is the Iwaver X-speed.
2005.05.08, 05:25 AM
i have atomic stock, M'z stock, iw Xspeed, and topcad R1
the ATM stock is a nice motor ~ but it has more potential if u use it with a fetted car,
the M'z stock is a non bearing motor which is a little faster than the kyo Xspeed.
the iw Xspeed is a crazily fast motor that i find useless to me.
topcad R1 is not a good motor at all.
by the way i've also tried atm Z1, and some tamiya motors on my mini-z.
2005.05.10, 10:12 AM
02-Racer
Isn't the blue power 50T/31 AWG?
They now have a special edition too: BB Endbel / 47T 31AWG
HaCo
2005.05.10, 01:15 PM
4play
PN Speedy NM. Ball-bearing, neo magnet, big comm 47T. It's the fastest I've tried so far. Will be trying the Atomic soon.
2005.05.10, 03:49 PM
Road Race Engineering
There has also been some contovirsy about the xspeed. Like the guy in that quote, you can get and amazingly fast or a slower one from the factory.....
I'm Driving:Redbull-Porsche PN Pancar
PN Enzo
Ferrari 575GTC
WilliamsF1#3's Gallery
Looking for a 01 Porsche body.
2005.05.10, 04:22 PM
and does anyone have the mini-z workshop motor? how is it?
PN Enzo
Ferrari 575GTC
2005.05.10, 04:38 PM
One thing I wanted to add about Iwaver's x-speed "pro" motor, T*yE*st states on their website that the PCB for the Iwaver 04 supports this motor. Don't know if this is true.
2005.05.10, 05:46 PM
the IW04 pcb can supposedly handle hotter motors (up to 4 amps)
i wouldnt try the iwaver x-speed pro with stock cars.... youll probably end up frying your board
i hear the atomic stock is a gd motor
you can tune how hard the springs push the brushes against the commutator for more torque, and it also comes with neo mags
atomic also claims this
RPM
Test Environment: Under 4.8V with 1.8g loading
: 30000 RPM
if you dont get that, the pn speedy in a ballbearing can is also a nice motor...
2005.05.24, 07:43 PM
MINI-Z MONSTER GARAGE
MR02RM, MR02MM, MZM,
Pro-Pulse Pro T-100 1/18 4X4,
2005.06.04, 09:59 AM
dogbreath, would the SE armature and endbell with atomic bb can and neos be safe for stock fets(no i wont be plowing full throttle into a wall )?I need this because the blue can was not pre-drilled and i have a pn mount .
PN Enzo
Ferrari 575GTC
2005.06.04, 10:39 AM
Again I can not vouche for the safe, I don't have any with stock FETs,but according to the manufacturer...that armature is safe....from everything I have heard, Neo's actually reduce amp draw? That would make the motor even safer than with stock magnets.
I did drill my own blue can and it works well (I also run the PN/Atomic style mount)
Atomic mount with Blue Power SE
....AND......
...You can get the Blue Power SE built in an Atomic BB can with Neos...it's a couple dollars more but should be worth it for the can and mags. You just have to ask for it built that way. Tell Thomas that Dogbreath sent ya.....
Hope this helped....
