Old 2020.11.18, 01:26 PM   #1
Steering "feel"
My EX6R has this setting, and I know several other KO-based TXs have a setting for steering feel. I tried different settings and I couldn't "feel" what it was doing. I found a description of it that I hadn't seen before:
So as an update to this, having recived my EX-6 and playing around with it it appears that it is a combination of throttle/steering mixing
a negative number dampens steering and makes it less sensitive at high speed while a positive number increases the steering sensitivity under full throttle (have not tried the inverse which is the throttle settings
so positive for drifting and negative for straightway/grip racing
this is really nice for racing as you can set the car up to response nicely in the corners and then under full power reduce the steering sensitivity but still keep the full throw of the wheel to make fine steering decisions
That makes sense, and is kind of cool. I'm going to give it another try with a negative number next time I race.
Old 2020.11.20, 08:35 AM   #2
CrazyRussian
CrazyRussian's Avatar
So, seems, its just add an Expo to the Steering, mixed with throttle.
I want to try to mix Stearing=>Throttle, by just decreasing trottle proportionally to angle of front wheels.
Mini-z MR-03 FHS (x2), AWD MA-010 Asf, Atomic AMZ, Robitronic Lap timer, Dasmikro rx board + Tx Module
CrazyRussian is offline   Reply With Quote
Old 2020.11.24, 12:17 PM   #3
Cool! I have this radio and hardly use any of the features other than the basic stuff. I'll have to give this a try.
МА-010 with MR-03 board - steering travel problem Bodom Mini-Z AWD MA-010, MA-015 35 2012.03.15 09:39 PM
Help. Steering won't center. Phenochilus Mini-Z Racer MR-02 8 2007.07.10 10:51 PM
MM02 steering problem pyro147 Beginner Questions 6 2006.03.29 03:54 AM
iWaver02 steering twitch / steering steps FIX!!! trueno92 iWaver 0 2005.04.23 01:09 AM
gpm steering parts problem marlboro Mini-Z Overland MV-01 1 2004.06.29 08:27 PM
