2011.12.19, 02:29 PM
#16
team xi
i heard it was going tobe the same size as a dnano or there abouts and that was from the kyosho uk guy and theers a rumour of a dnano kart at next years nuremberg toy fair
2011.12.27, 03:01 PM
#17
2011.12.27, 03:11 PM
#18
previously spakey
specs in english
Scale: 1 / 18; Length: 118mm (depending on the caster angle), width: 41mm, height: 73mm; Wheelbase: 85mm (depending on the caster angle) Weight: 85g; Motor: Coreless, E-Gyro-Motor: Brushless 7.000KV; Wheel diameter: V/32, H/35 7mm, 2mm; wheel width: V / 7.1 mm H11, 3mm; Sender: KT-19
RC functions Gas brake, steering
Description
. You let the wind blow around the ears and enjoy the ride on two wheels. . For now, the action really begins. Mini-Z Moto Racer. Mini-Z Racing Experience a new generation to discover new possibilities with the Mini-Z Racer Moto.
With the motor racer KYOSHO provides a model of the first Mini-Z series with two wheels instead of four, and despite lower number of wheels increases the fascination that this category entails.
The detailed trim and attractive overall appearance to give the bike showcases the charm of a model, but far from it ...!
Equipped with an e-gyro system in the rear is the model even when driving extremely slow speeds, stable and overturns not so easy.. Thus, even beginners can easily rotate after a few minutes and enjoy your first few laps, the dynamics of the model. Die The sensitivity setting of the gyro electronics can be comfortable at the new 2.4 GHz FHSS KT-19 remote control are made. . This makes it even easier to adjust the level of intervention by the electronics of their own driving skills. And if it does once the "fall" is, can be absorbed through the crash bar fitting designed to run without manual intervention again.
! But cruising is not all! . For as the name implies, the bike is a racer on the track and feels equally at home as in your living room. . So the bike on the track to the limit can be placed on the chassis has fully adjustable suspension points. Thus, the suspension on the front and rear adjustable and also the ground clearance can be adjusted. Similarly, the delay can be set on the front wheel to the steering characteristics of the motorcycle to change and adapt to circumstances.
! And more technology is in this model! Damit der Betrieb besonders komfortabel ist kann der . In order for the operation is very comfortable, the power battery to be recharged directly on the remote control. . Optionally, provided with a USB wall charger for drive battery can be connected to a port on your existing computer. When you load on your PC can even drive two batteries are charged simultaneously, which leads to even more extensive driving pleasure, because the load times are significantly reduced.
Features Features
• • MC-01 Mini-Z Racer Moto-wheel drive with kreiselunterstütztem
• • Motherboard with innovative 2.4GHz wireless technology
• High-resolution digital steering servo with coreless motor
• • Operation is no conventional quartz
• • Infinitely adjustable E-gyro stabilization system for driving
• • Full ball bearing drivetrain
• Charger connector on the remote control
• • Painted bike is with all the decorations (Fine Hand Polish)
• • Sophisticated front axle with a lot of mechanical grip
• • Infinitely adjustable ground clearance
• • Adjustable caster angle adjustment for the steering behavior
• • Up to 40 bikes can be operated simultaneously
• • high-grip racing tires
• • Drive chassis with pre-constructed 3-Channel 2.4GHz FHSS KT-19 Remote Control
• LiPo charger with USB connection for power battery
• • Perfect look through detailed body
Erforderliches Zubehör Required Accessories
• 4 St. Team Orion AAA 1100mAh RT Akkus, Best.-Nr. • 4 pcs 1100mAh RT AAA Team Orion batteries, Order No. ORI13201 (Sender) ORI13201 (transmitter)
• Ladegerät EZ Pro-Am Digital 12/230V, Best.-Nr. • EZ Charger Pro-Am Digital 12/230V, No. ORI30402 ORI30402
Zielgruppe Target group
Einsteiger, Fortgeschrittene & Profis Beginners, advanced & professional
mbmzr
let's go racing
2011.12.27, 03:46 PM
#19
I would like to know if these will be available without transmitter and if the work with and EX-5UR ASF or any other 3 channel transmitter.
2011.12.27, 04:10 PM
#20
previously spakey
maybe with a fhss module.
mbmzr
let's go racing
2011.12.27, 04:13 PM
#21
if it's the same 2.4 asf as the mini-z which it seems to be with the kt-18, then the 5ur would work. basically, anything that supports tiki tiki would work if i understand how tiki tiki works correctly.
2011.12.27, 04:21 PM
#22
previously spakey
asf and fhss are diffrent
mbmzr
let's go racing
2011.12.27, 04:25 PM
#23
ahh, i see that in the description. that will certainly make things a bit more complicated adding another system to the mix. i still question why call it mini-z moto? especially if it doesn't share the 2.4 asf? scale alone doesn't seem like a good enough excuse given that they are using it for various scales now.
2011.12.27, 04:33 PM
#24
Is the 3rd channel necessary? Or just to operate tiki tiki like in the buggy and models that support it?
New radio is uglier than the old kt18 :| I'll also be pretty pissed if my asf module won't work on it, a bit of a deal breaker unless it really is that awesome. Also a shame they didn't use the dnano batteries, but I'm guessing it's due to excess weight from the huge plastic case being too high up?
2011.12.27, 06:05 PM
#25
And it begins... PN tires, ball bearings, adjustable shocks, lexan bodies, swingarm extensions, chrome frames, streetfighter light kits, lightweight foam riders. So much for saving any money next year!
Can't wait to build a little cafe racer. Wouldn't be surprised to even see an old Harley out on the track in a year or two with a little foamed hippie behind the bars.
2011.12.27, 06:28 PM
#26
previously spakey
You forgot the reflex oil forks and delron gears
mbmzr
let's go racing
2011.12.27, 07:12 PM
#27
oh... brushless...
Now I know what MR-04 would contain....
2011.12.27, 08:24 PM
#28
Originally Posted by NoBrainer
oh... brushless...
wow, finally Brushless, on a Z product, super!!!!!
not only that but also the only brushless & lipo combo...finally fully updated electronics
I would certainly hope so, brushed motors are yesteryears news and encourage cheating in stock classes time to move on.
regarding FHSS sounds as if out of all KO transmitters only Eurus will be able to run this bike since the only one currently with an FHSS module option for full size, hope ko considers FHSS for others too in case tx's can run them...ton of Helios & Ex's out there very recently purchased!
This bike rocks, wouldn't be surprised if it really takes off.
right now the smallest readily available racing grade class is 1/8 scale and on most 10th scale tracks it feels too large & too challenging to keep on all 2's for any extended time for the average driver. assuming zmoto performs with egyro should solve both above mentioned issues. good stuff!
2011.12.27, 09:15 PM
#29
Buggy or motor, buggy or motor. Damn you kyoshooooo
2011.12.27, 09:45 PM
#30
We know how that goes eventually , Buggy & Motor & New F1 parts (body etc)....ouch, it's going to be an expensive year!!
